Dell Vostro 15 no charge
  • dclass-pro
    • Dec 2022
    • 157
    • Italy
    Hi guys happy new year to all,
    I have a problem with a DELL Vostro 15 (code on main 3263) that doesn't increase the battery percentage.
    Its original battery is dead, I changed it with 2 compatible batteries, the pc sees the battery also from the bios and says everything is ok, but when I put it on charge it always stays fixed at 71%, I measured the voltage across of the battery and 15V arrive only when the battery is inserted, there are also 3.3v on the central poles of the data exchange. What can it depend on?
    I am attaching the wiring diagram. Thank you all
  • mon2
    • Dec 2019
    • 14172
    Re: Dell Vostro 15 no charge
    Remove the smbus ESD diodes at D4305 and D4306 and test again.
    • dclass-pro
      • Dec 2022
      • 157
      • Italy
      I removed the 2 diodes and it still doesn't work...
      • mon2
        • Dec 2019
        • 14172
        Measure the voltage to ground of each pin on the BATT1 connector.
        Confirm the same voltages are present on the other side of RN4302.
        Do check for corrosion in this area. Confirm the battery contacts are mating.
        The battery properties are extracted over the SMBUS interface and is with the BMS module inside each battery pack. If the interconnect is not defective then the MEC may be at fault. Wait on others to comment if that device is programmable or not.
        • dclass-pro
          • Dec 2022
          • 157
          • Italy
          i confirm that the voltages are ok and RN4302 is ok, maybe it can depend on the MEC, but maybe can look for the original battery?
          Can I reassemble the 2 diodes D4305 and D4306?
          • mon2
            • Dec 2019
            • 14172
            Yes, place them back. Sometimes, the esd diodes impact the SCL or sda lines and corrupt the communication between the MEC and the BMS module.
            With your case, can you check the details of you battery? Such as serial number, number of charge cycles, etc. ?
            Using an Arduino, you can do this.
            Have linked the github article on this topic in this forum. It is possible that the battery is a fake. You can try another brand from Amazon and return it if it does not work.
            • dclass-pro
              • Dec 2022
              • 157
              • Italy
              yes i already tried a new battery but i have the same problem
              • mon2
                • Dec 2019
                • 14172
                Then it appears to be down to MEC controller which is the smbus master. Do you have a scope or bus analyzer? Even a $5 usd bus analyzer from AliExpress can work to monitor the smbus lines. Then you can confirm if the MEC is communicating with the battery pack or not.
                Using an Arduino, you can confirm the serial number, etc of the battery pack.
                https://github.com/ArminJo/Smart-Bat...fo_For_Arduino
                • dclass-pro
                  • Dec 2022
                  • 157
                  • Italy
                  I don't have arduino but I have an oscilloscope and I can check if there is data exchange, but I think there is otherwise it wouldn't have seen the battery.. it's a strange defect
                  • mon2
                    • Dec 2019
                    • 14172
                    Yes, do check for pulses on the SCL and SDA pins.
                    The battery detect is a single pin status check at PBAT_PRES#. If this pin is LOW = 0 volts (active low signal), the battery is considered to be present.
                    Of concern is why the battery gauge remains a fixed value. This is a digital value to be read over the SMBUS interface. Then the firmware inside the MEC (8051 microcontroller) converts the binary value to a charge percentage.
                    • dclass-pro
                      • Dec 2022
                      • 157
                      • Italy
                      I confirm that the data exchange on the 2 pins of the battery is there, perhaps it requires the original battery..
                      • mon2
                        • Dec 2019
                        • 14172
                        Yes, try a different brand or if possible, the original battery.
                        • dclass-pro
                          • Dec 2022
                          • 157
                          • Italy
                          I also tried with its original battery and it has exactly the same problem, data exchange present but it does not charge ... I try to order the new original one and I will let you know
                          • mon2
                            • Dec 2019
                            • 14172
                            Which line did you probe with the scope? SCL or SDA ?
                            Check to see if there are similar pulses on the other SMBUS interface line.
                            • dclass-pro
                              • Dec 2022
                              • 157
                              • Italy
                              I probed both lines
                              • mon2
                                • Dec 2019
                                • 14172
                                Should have asked earlier, are you using the recommended and official power adapter for this unit ?
                                The logic board does ping the power adapter for the power rating using the PS_ID single wire interface.
                                If the PS_ID line is defective (??) or the wrong adapter is used, the battery will not charge.
                                Can you measure the voltage to ground of the PS_ID line for the power adapter?
                                • mon2
                                  • Dec 2019
                                  • 14172
                                  See attached for test points of interest.
                                  If the host logic board is unable to properly detect the power adapter, the battery will fail to charge.
                                  • dclass-pro
                                    • Dec 2022
                                    • 157
                                    • Italy
                                    I use the original charger and I also tried another original charger, same result.
                                    On the 2 points you ask, I have 3.2V
                                    • mon2
                                      • Dec 2019
                                      • 14172
                                      Does the BIOS report the details of the power adapter?
                                      If not, remove PQ4301. Then bridge the source & drain pins using the PCB pads for PQ4301. You may be able to do the same with a solder blob @ PR4306.
                                      Confirm the resistance of PR4305 against the schematic value.
                                      • dclass-pro
                                        • Dec 2022
                                        • 157
                                        • Italy
                                        I confirm that in the bios it shows the values of the power supply and that the PR4305 resistor is 33ohm
                                        • MahmoudNasser
                                          Dell Vostro 3400 battery does not charge beyond 55%
                                          by MahmoudNasser
                                          I have a Dell Vostro 3400 battery does not charge beyond 55%
                                          I tried another file... the battery charge exceeded 55%, but it entered manufacturing mode and it did not count from it.
                                          - I rebuilt the basic BIOS and Clear Me, but without results
                                          What if the same situation does not charge the battery more than 55%?
                                          Can someone help me?
                                          The original BIOS file is attached
                                          Device Data
                                          Model Dell Vostro 3400
                                          CPU:i5-11th
                                          SN 7G4BRF3
                                          MP PartNumper:LA-K032P REV 1.0 (A00)
                                          Bios Chips:XM25QH64A...
                                          10-09-2023, 03:58 PM
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • razenxd
                                          How can I charge that battery pack?
                                          by razenxd
                                          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                          Now, I have noticed a few things.
                                          The "dead" battery, while connected to charger and NOT Charging will...
                                          12-05-2024, 06:11 AM
                                          DELL Vostro 3470 Vostro 3400 i5-9400 Specification for Upgrade or Repair
                                          This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                          09-12-2024, 03:44 PM
