Asus UX433FAC - batery dead after short on VIN rail
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Hello.
    Have this Asus UX433FAC that came with shorted mosfet on main power rail. After replace laptop works ok, but battery is dead. Laptop show charging but voltage on battery is 0.2V. when remove battery voltage on battery connector goes to 8.5V, but when connect battery again it goes down to 0.2V.
    can that short shorted battery? batmon show that battery is full at 80%
  • mon2
    • Dec 2019
    • 14693
    Re: Asus UX433FAC - batery dead after short on VIN rail
    Sounds like a crap battery. Test with a fresh one.
    Check the voltage to ground on the SMBUS lines (SDA / SCL) on the battery which spit back data from the BMS inside the battery pack.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3628
      • slovakia
      SMBUS lines looks ok 3.3V when connected and charger attached. measured mosfets and all looks ok. Battery was ok before. batmon shows good capacity. dont have another battery so i like to be sure that problem is battery because battery is not cheap
      i unwrap battery and cells is all 4.1V. on some points of BMS i measure 12.5V
      can be bms measured if it is ok?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3628
        • slovakia
        maybe when capacitor shorted and system was on battery BMS detect overload and cut off cells
        • mon2
          • Dec 2019
          • 14693
          1) to test the BMS, you will need an I2C /smbus master like an Arduino. Then using the 2 wire interface, you can ping and read out the battery vital stats.
          Review the black hat article posted here:
          https://www.badcaps.net/forum/showthread.php?t=113773
          There are numerous public articles on how to use an Arduino to dump such data out of laptop battery packs.
          https://github.com/ArminJo/Smart-Bat...fo_For_Arduino
          2) if the battery is on your work table, there is a valid output voltage on the battery pack contacts?
          This voltage goes to ~zero only when mated to the logic board?
          If yes, the mosfets on the logic board are still suspects.
          3) which battery charger IC is onboard this logic board? Is it the 'BQ' series?
          4) remove all power/no battery. For each mosfet, measure the resistance across the mosfet pins:
          Source & drain
          Source & gate
          Gate & drain
          Post each measurement.
          It is possible that battery or another mosfet is leaking. That is, the mosfet is enabled when it should be off.
          For example, often, the battery mosfet should be off when the battery adapter is connected.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3628
            • slovakia
            Source & drain
            Source & gate
            Gate & drain
            thanks i will look at it. i have airduno and some UART reader
            2. battery packs have all 4.1V and together 12.3V . I mean that without battery on bat. connector on board i have 8.5V, but when connect battery it goes to 0.2V. not fast so it more looks like controlled
            3. it is BQ24790
            4. measured and all lokks good 500ohm/infinity
            Looks like the battery can be problem, because i found shorted mosfet on BMS. remove it and it is really shorted S-D. but after replace still same behavior. on one of that output mosfet i have 12.3V but nothing on battery output
            so controller can store hard fault
            can i use battery from other laptop with same connector and pinout?
            • mon2
              • Dec 2019
              • 14693
              What is the voltage on the battery connector while the pack is not connected to the laptop? This is the contact on the actual battery pack, not the logic board connector.
              Just interested to know if the battery cells are working to output a valid voltage or not.
              Mosfet resistance should be in hundreds of Kohms or higher if they are not defective.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3628
                • slovakia
                without connected battery, no voltage on any pins of battery connector on battery. i know how to test mosfet
                • mon2
                  • Dec 2019
                  • 14693
                  No direct experience with your other question so proceed with caution. As noted by others, it is a fire hazard and risky topic. I believe that events like yours can lock up the BMS. The Arduino tool may confirm this.
                  Also, on AliExpress, you can purchase clones of the EV-2400 tool which with the software from TI, you can communicate with the BMS. We just placed an order for another tool to perform some tests. We have the original as well from TI but is much higher cost. In summary, it is a usb to smbus bridge but the TI battery tool searches for this tool and respective usb headers.
                  • mon2
                    • Dec 2019
                    • 14693
                    We ordered this one to compare to our original:
                    US $27.00 | EV2400 Battery Metering Chip Programmer UAV Battery Debugger Compatible With EV2400 EV2300 For TI Voltmeter Chip Writing Tool
                    https://a.aliexpress.com/_m04Jm8m
                    • mon2
                      • Dec 2019
                      • 14693
                      With no voltage, I think the BMS is dead or locked up.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3628
                        • slovakia
                        i think that too. that tool is interesting, but this is first time that i will need it for few years. can it check all batteries? it is not expencive so maybe i buy it for fun
                        • harp
                          • Jun 2022
                          • 645
                          • Planet Earth
                          Do simple thing first.
                          If you have correct voltage on batt and no voltage on connector, first check the fuse (fuse with heater). If it is ok, then trace and confirm where is output plus pin on connectot (who no voltage) and do briefly about half second or so a connect thru 47R to plus on battery (12v).
                          Check if voltage on connect return.
                          • mon2
                            • Dec 2019
                            • 14693
                            I am far from being an expert on this topic but learning through the internet.
                            From my understanding so far, there are common commands that you can throw at all battery packs using the USB to SMBUS bridge (2 wire mode = I2C style).
                            The TI tool should allow you to extract this block of BMS information from any pack using the common commands.
                            Then there are register specific commands that only TI based BMS devices can interpret. This tool allows for that access.
                            For example, it appears that the TI BMS fuel gauge chips are buried inside the Macbook battery packs so you can dig deep - including unsealing which requires a passcode but the passcode for Macbook packs is public. Proceed with extreme caution as that level allows you to adjust the calibration data for the battery cells.
                            The software tools are available from the TI website. You should be able to download it to get a feel for the tool.
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3628
                              • slovakia
                              i got that analyzer you recommended but cannot find anything on that TI site. it is huge company so have huge website
                              • mon2
                                • Dec 2019
                                • 14693
                                https://www.ti.com/tool/EV2400
                                https://www.ti.com/lit/zip/sluc674
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3628
                                  • slovakia
                                  thanks mate
                                  • nagkiller
                                    Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
                                    by nagkiller
                                    Hello everyone!
                                    This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
                                    After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
                                    Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
                                    The attached boardview file is very similar to this grafic card, which I am basing the repair on.
                                    I would like some...
                                    05-10-2025, 09:19 AM
                                  • Victor Moreira Silva
                                    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                    by Victor Moreira Silva
                                    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                    Well, my decice specs are the following:
                                    Model: Acer Nitro 5 AN517-54-55T5
                                    CPU: Intel Core i5-11400H
                                    GPU: NVIDIA GeForce GTX 1650
                                    Motherboard: GH51G LA-L181P Rev:1c
                                    The symptom:
                                    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                    05-26-2025, 10:49 AM
                                  • JimMc0
                                    Gigabyte GA-H61M-USB3-B3 dead short 3.3v rail to ground.
                                    by JimMc0
                                    Hi there,
                                    I discovered this forum through a youtuber who teaches electronic repair. I've been trying to troubleshoot my dad's old PC which is a Gigabyte GA-H61M-USB3-B3 and will not power on. I discovered a dead short on the 3.3v rail at the ATX connector so I used a bench power supply to feed 3.3v into the ATX connector and sunk about 400mA into the board (I hope that's not too much!). I used a FLIR camera to identify the problem area:
                                    The chip seems to be the following, an ITE IT8892E 1108-CXS which seems to be a PCI bridge?
                                    03-27-2024, 08:36 AM
                                  • Mabot17
                                    ASUS gaming laptop GL704GV GPU DEAD SHORT
                                    by Mabot17
                                    Hello i need help to fix this laptop,at least a discrete to UMA conversion if it's possible.
                                    i took a photo of what i found,NVIDIA gpu side is 100% shorted as i desoldered power line coils and mosfet side is ok.
                                    Even without coils laptop still not power on.Main power rails,bios,1v,3,3v and 5v are present...
                                    05-10-2025, 11:04 AM
                                  • grimacelord
                                    Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                    by grimacelord
                                    Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                    After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                    I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                    10-24-2024, 12:31 PM
