Need PS4 Slim Power Supply Diagram N160A006P
  • fab13
    • Dec 2021
    • 109
    • France
    Hello to all,
    I have my power supply that does not provide 5 Volts and I would like to have a diagram for the PS4 Slim N160A006P power supply
    Thanks a lot
  • fab13
    • Dec 2021
    • 109
    • France
    Re: Need PS4 Slim Power Supply Diagram N160A006P
    It's for 17-160p1a
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
      12 volt switching power supply modification to 14.5 volts before blocking diode add
      by sam_sam_sam
      I saw this switching power supply on eBay and wanted to see if could be modified to run 14.5 volts before the blocking diode was add and this switching power supply seems to have no issues doing this
      I did recap the switching power supply except the the main filtering capacitors and I managed to break the selector switch for the voltage setting but just jumped it
      One note I used 25 volt capacitors on the output side of this power supply because they used 16 volt capacitors and because I am running the voltage up a little bit higher 12 volts to 14.5 volts there would...
      04-11-2021, 11:01 AM
    • Andreas_de
      Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
      by Andreas_de
      Hello!
      i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
      Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
      Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
      04-12-2025, 10:38 AM
    • modtool
      Sony PS4 slim CUH-2216A power supply ADP-160FR not working after short in PFC
      by modtool
      Dear forum members,
      I'm working on this power supply for ps4 slim, that behaves in a similar manner as other cases but I can't find a way to solve the problem.
      When it came to me, externally the ps4 had standby voltage, clicking the disc eject button made the triple beep (without disc inside) and cliking on the power button made the blue power light turn on and then all turned off within 1 second.
      When I opened it up, I found these components shorted:
      Q6 24N60M2
      IC41 1612A (not really shorted but had a hole on it and all pins measured open circuit but the 9th...
      05-31-2023, 08:09 AM
