Watches can have bad caps too! 735XT Repair
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    I had some time today spare, normally we would just board swap to reduce labour time. This Garmim 735 was stuck in a boot loop. Battery shutting down the voltage (bms shutdown) decided something could be short so went hunting.
    Found some shorts near the cap I replaced, so put 1v and some IPA this one soon showed up. Replaced the cap and fixed! Just thought I'd share
  • CapLeaker
    Leaking Member
    • 8352
    Re: Watches can have bad caps too! 735XT Repair
    I figured this had to come at some point. Shorted caps is a watch… I just wish the battery run time would be better. Cool repair!
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
