Inogen One G3 portable oxygen concentrator Help!!!
  • ramondo
    Confused Member
    • Jun 2015
    • 39
    Posted here because this forum has the most viewers..Point me in the right direction PLEASE.
    I am looking for any guidance as to the repair of an "Inogen One G3 portable oxygen concentrator" My problem is how to reset the battery pack after replacing the LiIon battery cells. Battery pack shows full charge on pack indicator leds, unit does not recognize battery pack, Unit works with ac adaptor with no error codes.???
    Thanks to all for being__WAR_KITTENS____!
    • Jul 2011
    • 6070
    Re: Inogen One G3 portable oxygen concentrator Help!!!
    Okay please post some pictures of of the battery pack you have
    What was the battery pack doing before you replaced the battery cells this information is very important to know I will explain later
    If possible can you please take pictures of the inside of the battery pack and the circuit board or boards if it has more than one
    • WayOfTheRoad
      • Aug 2021
      • 59
      Yes, please post all the photos you can as we will need to see it to properly help (and even then it may not be enough). Please post what you can and any details you can.
      • brispuss
        Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
        by brispuss
        Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
        Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
        I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
        12-28-2022, 02:58 AM
      • razenxd
        How can I charge that battery pack?
        by razenxd
        it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
        At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
        Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
        Now, I have noticed a few things.
        The "dead" battery, while connected to charger and NOT Charging will...
        12-05-2024, 06:11 AM
        Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
        I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
        So I have put them on the battery testing machine to drain each battery cell down to...
        09-04-2022, 04:45 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
        I bought this from an eBay seller but unfortunately they only had one
        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
        I bought three of from them to also make battery packs with this output power limit in mind
        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
        04-23-2025, 05:50 AM
