universal tdk inverter.what is the little white thing ?
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    its a universal tdk inverter thats refusing to send the turn on external mosfet on .
    • 31014
    Re: what is the little white thing ?
    5-1?? must be a diode
    • petehall347
      • Jan 2015
      • 4426
      • United Kingdom
      ok will diode test it . its not shorted i checked that already
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        tests as a diode .mystery solved .. now need to see why its not turning on .
        • CapLeaker
          Leaking Member
          • 8146
          Re: universal tdk inverter.what is the little white thing ?
          5.1V zener diode? Maybe it isn’t zenering correctly?
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            its not doing anything as no power is getting to the inverter .
            i am struggling to see how it is supposed to switch on .
            this is it ..
            CXA-P1212B-WJL-1
            i cant see how the main board can supply anything but 12v .
            • CapLeaker
              Leaking Member
              • 8146
              maybe post some pics of the whole thing?
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                will post pic of the mainboard where the inverter plugs in and the inverter but plenty of pics and data sheet online for inverter . i can switch on the 12v by switching the fet on the mainboard on by making the gate low but inverter still not on . well no lights are coming on .i dont have x100 leads for my meter .
                • petehall347
                  • Jan 2015
                  • 4426
                  • United Kingdom
                  pics .
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    i can see q1 should be turning on to send u28 low and turning u28 on to supply the 12v but cant see any connections on the mainboard for anything else but 12v .
                    • petehall347
                      • Jan 2015
                      • 4426
                      • United Kingdom
                      inverter pdf .
                      https://www.alldatasheet.com/datashe...1212B-WJL.html
                      • R_J
                        • 9535
                        Is the fuse good on the inverter? Do you have about 2v on pin 5 of the inverter to turn it on?
                        Check which pin Q1 base (R63) connects to on the inverter, If it connects to pin6, that is the protect line.
                        • petehall347
                          • Jan 2015
                          • 4426
                          • United Kingdom
                          what fuse ?
                          i cant see where 2v is supposed to come from .. should it come from the mainboard ?
                          • R_J
                            • 9535
                            That looks like a fuse on the inverter marked 20 (2Amp), it should be connected to pin 1, The 2.5 volts needs to be on pin5, this is what turns on the inverter look at the datasheet, Pin5 Vmt 0~.4v=off, 2.5v~vin = on
                            The on/off signal should come from the main board.
                            • petehall347
                              • Jan 2015
                              • 4426
                              • United Kingdom
                              fuse is fine .
                              will check all pins voltages again shortly .
                              • R_J
                                • 9535
                                You should be able to test it with a 12v bench supply (or even a 9v battery) then use a 1k resistor between pin5 and pin1 to turn it on.
                                What is that mess around C337 on the main board? does that line connect to pin 5 on the inverter?
                                • petehall347
                                  • Jan 2015
                                  • 4426
                                  • United Kingdom
                                  pin 5 goes to q1 base via r63 ..looks to me this should switch on u28 to provide 12v which is on q1 emitter or collector one of those goes to ground .
                                  • R_J
                                    • 9535
                                    I count 7 pins on the inverter and 5 pins on the main board. which pins on the inverter connect to which pins on the main board?
                                    I doubt pin 5 of the inverter connects to R63, are you sure its not pin 6 on the inverter board?
                                    • petehall347
                                      • Jan 2015
                                      • 4426
                                      • United Kingdom
                                      pin 5 inverter goes to centre pin main board . which goes to r63
                                      • R_J
                                        • 9535
                                        That will not work. Pin 5 of the inverter is the ON OFF pin, you can't control this from the base of a transistor.
                                        It makes more sense that pin 6 on the inverter connects to R63 and then the base of Q1, If the inverter has a problem, it will output 5v on pin6 turning on Q1 which will turn off the 12v to the inverter
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
                                          MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                                          This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 07:46 AM
                                          MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                                          This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-06-2024, 07:29 AM
                                          MSI Prestige P65 8RF-457BE Creator White Notebook P Specification for Upgrade or Repair
                                          This specification for the MSI Prestige P65 8RF-457BE Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-457BE Creator White boardview and P65 8RF-457BE Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 07:25 AM
                                          MSI Prestige P65 8RF-445ES Creator White Notebook P Specification for Upgrade or Repair
                                          This specification for the MSI Prestige P65 8RF-445ES Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-445ES Creator White boardview and P65 8RF-445ES Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
