Strange relay Programmable outlet
  • bios321
    • Sep 2017
    • 19
    • czech republic
    Hi all
    The culprit ELEWAY BF24-1A-H-S 24VDC relay.
    Item a programmable outlet Brennenstuhl dt v2. It just won't turn on and off when it should. The reset works fine but I do not hear the relay clicking on/off. I have two of these outlets, one works fine the other one not even close. I think it is the relay but I cannot find it to buy. Also I cannot find a similar one. I cannot find a datasheet for this relay. So I am stuck. Any help, any ideas will be greatly appreciated.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Strange relay Programmable outlet
    I think it might be be BE24 not BF24, then lots show up in search.
    • bios321
      • Sep 2017
      • 19
      • czech republic
      Definitely it is an ELEWAY BF24-1A-H-S 24VDC. I have also found a similar problem on the internet.
      http://ugyotaku.web.fc2.com/yahoo2/PT50DW/PT50DW.htm
      If you'll scroll down you will get to a picture of it.
        • 31182
        these stupid automation things usually fail in the psu area.
        if it uses a capacitive dropper and the cap is failing it will supply enough current for the electronics but not the relay coil.
          master hoarder
          • May 2008
          • 12175
          Maybe that's a cheap knock-off clone of a BE24 relay?
          In any case, just take out the relay and measure it, then compare to the size of the BE24. If coil voltage as well as contactor current and voltage ratings match, just use the BE24.
          And looking at the pictures on the link that O/P provided... yes, it does look like a capacitative dropper circuit. Does 0.47 uF sound inline for such purpose? At least it is an X2-class rated cap and not just a regular PP/PE.
          On that note, the only programmable plug-in timers I have are the simple ones with a synchronous motor and you put little red and green tabs on a turning round wheel to set the On-Off times. Not very accurate and looses timing if power goes off for an extended time... but at least it doesn't fail.
          • redwire
            • Dec 2010
            • 3912
            OP what makes you think it's the relay?
            It's usually the dropper-capacitor going low value, the small electrolytic going bad or just crappy soldering inside. The zeners can go bad with age.
            The 24V relay coil should measure around 1,400ohms and needs at least 18V to pull in. It looks like a typical high capacity cube relay. Like Songle SRD-24VDC-SL-C or Omron G5LE etc. but 16A is harder to find.
            I have a Geya astronomical timer, it's supposed to turn on and off at sunrise/sunset but the manual absolutely terrible and the firmware seems so bad I gave up on getting it to work.
            It uses a 48VDC relay coil and I drew a schematic of the power system, they're all the same - resistor+capacitive dropper, 3.3V zener for MCU power and NiMh battery to save settings.
            • CoinCoin88
              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
              by CoinCoin88
              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
              09-15-2025, 03:36 AM
            • jm1234
              9V relay temperature 40C
              by jm1234
              Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
              I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
              05-09-2024, 03:03 AM
            • subroto
              Programmable and non-programmable SIO list
              by subroto
              ene kb9012 programmable
              ene kb9016 programmable
              ene kb9018 programmable
              ene kb9022 programmable
              ene kb9028qc programmable
              ene kb9010 programmable
              ene kb3930qf/b1 programmable
              ite it8585e programmable
              ite it8586e programmable
              ite it8985e programmable
              ite it8587e programmable
              ite it8522 programmable
              ite it8987e programmable
              ite it8589 programmable
              ite IT8380E programmable 192kb
              ite IT8380VG programmable 192kb
              ite IT8995E-128 programmable
              ite it8886H...
              01-13-2018, 09:15 AM
              Mitsubishi CNC switching power supply board dead / relay board bad diode failure
              I was working on this CNC machine today found no keyboard functioning no control relay powering on
              The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
              Found shorted diodes on main controller relays there are 3 of them that...
              01-07-2023, 05:43 PM
            • CuriousJohn
              Burco boiler power problem
              by CuriousJohn
              Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
              Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
              This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
              12-22-2024, 10:25 AM
