Troubleshooting Electric Blanket
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Troubleshooting Electric Blanket
    check resistance of the element ... i guess it will be about same as a 60w to 100w light bulb .
    • DanFen
      • Apr 2017
      • 201
      • Malta
      Mind explaining in baby terminology, what you're referring to when saying "element"?
      EDIT: At this stage I am not even connecting the actual blanket, the controller should light an LED if it's functioning (I also know cause I have a very similar one that works, LED lights on even with the blanket disconnected).
      • R_J
        • 9535
        There are two switch contacts, one on the line side one on the neutral side, They both need to be making contact, There must be a plastic actuator that presses them so they make contact. I would be carefull there will be 240vac across them.
        I also just notice a smd resistor that seems to be missing, It is R2, it is part of a series of 4 resistors
        • DanFen
          • Apr 2017
          • 201
          • Malta
          Are you referring to these two?
          • R_J
            • 9535
            Yes I am, I also mentioned a missing R2 resistor, it likely fell off at one time and is missng which is likely causing the problem. It seems to be for the low voltage that supplies the ic. Check if it is still in the case or on the surface where you opened the case.
            This is why it's not working, R2 is part of the 4 resistors that drops the ac voltage that feeds D1, which is then clamped to around +5v by ZD1 (N8). That feeds D2 and capacitor C1
            • DanFen
              • Apr 2017
              • 201
              • Malta
              #26
              Yeah I'm extra careful with that 240V thanks for the reminder
              To be honest, those contacts seem to be making contact already, and there's no device that pushes them. Not sure what the idea behind it is. Tried to take a photo using a magnifying lens.
              Now I see the missing resistor. I'll try to find an equivalent one from a laptop/computer motherboard. Should have done a better visual inspection! You've got a good eye
              Yes I am, I also mentioned a missing R2 resistor, it likely fell off at one time and is missng which may be causing the problem
              • R_J
                • 9535
                R2 should be a 1002 (10K) The contacts could be making connection now, but I suspect there is a slide (power on/off) or something in the case that causes them to open.
                • DanFen
                  • Apr 2017
                  • 201
                  • Malta
                  #28
                  Yes found the mechanism, when it's 0 it moves a plastic underneath them and stops the contact. Thanks for the explanation
                  Hope I'll find a 1002!
                  • DanFen
                    • Apr 2017
                    • 201
                    • Malta
                    #29
                    My luck says not today, I couldn't find any 1002 resistors on any PC/Laptop board.
                    • R_J
                      • 9535
                      look for a couple 5k and put them in series, it does'nt need to be exact, as long as it is close to 10k, 15k would likely work as well.
                      • DanFen
                        • Apr 2017
                        • 201
                        • Malta
                        #31
                        Would 103 work? It's 10k, but smaller in size.
                        • R_J
                          • 9535
                          It should work to test, I would try and find the correct type. The original must have fallen out at one time, too bad it was'nt still in the case.
                          • DanFen
                            • Apr 2017
                            • 201
                            • Malta
                            #33
                            I can order a batch of 100 for 81 euro cents from Aliexpress. It's just a matter of waiting and having 99 other resistors sitting there.
                            • R_J
                              • 9535
                              The 103 will likely be ok, but being smaller the wattage is likely lower so it could just open up after a while.
                              • DanFen
                                • Apr 2017
                                • 201
                                • Malta
                                #35
                                Thanks for your help I'll just place the order and then update this thread when it's installed.
                                • R_J
                                  • 9535
                                  It will be fine to try, that way you will know if it is going to fix it or not.
                                  • DanFen
                                    • Apr 2017
                                    • 201
                                    • Malta
                                    #37
                                    OK, I'll give the 103 a try later on and post feedback.
                                    • DanFen
                                      • Apr 2017
                                      • 201
                                      • Malta
                                      #38
                                      I've installed the 103 resistor and the LED is now on. Haven't checked it properly with the blanket element yet.
                                      I still have the 1002 on order, so I'll replace with that as soon as I have it
                                        • 31015
                                        103 and 1002 are the same part,
                                        the current/wattage is not printed on them but is implied by the physical size!
                                        • R_J
                                          • 9535
                                          Good to here it's up and working, I wish I would have noticed the missing resistor earlier, It was'nt untill I was tracing the low voltage circuit that I noticed it.
