Li-ion AAA replacement with li-ion pack
  • clearchris
    • Dec 2013
    • 687
    Ok, I have this device, a skulpt chisel. It's acting funky, and the battery never goes higher than 70% charged anymore. I popped the case open, and instead of NiMH batteries I was expecting (older version had them), I found Li-ion batteries. Two 10440 AAA form factor 3.7v 320mah batteries. I can find 10440 batteries, but finding ones with solder tabs is a challenge. I'm really not into ebay li-ion batteries. I'm not soldering the tabs on myself, it's not worth the risk.
    So, I have found a flat pack that will fit. I can cut the plug, solder the wires on, tape the pack down, and it's all good.
    https://www.adafruit.com/product/258
    My question is, will the electronic protection circuits on this pack interfere with the charging circuits on the board? The standard li-ion AAA batteries don't seem to have any obvious protection circuits on them.
    Thanks!
    Battery Datasheet:
    https://cdn.badcaps-static.com/pdfs/...14bb7e5e7b.pdf
    Battery Protection IC
    https://cdn.badcaps-static.com/pdfs/...4dd1bdc4ae.pdf
    And there is an 8814 mosfet which i assume cuts off the battery if something bad happens.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Li-ion AAA replacement with li-ion pack
    If these two current Li-ion AAA batteries are in parallel there without any protection... oh boy!
    I don't imagine the Li-ion pack with protection will have issues with the charging circuit, but I'm not an expert in this area. Will wait for someone else with more experience to chime in here.
    • clearchris
      • Dec 2013
      • 687
      They do appear to be in parallel, but from my readings on li-ion charging it's not neccessarily a problem. You have to build a "balance" phase into the charging. At any rate, I think I'm going to a single cell pack, so it should be safer in that regard.
        • Jul 2011
        • 6057
        You should be fine with this battery but do not remove the protection board
        Unless the unit requires a different cut off voltage to the batteries then that could be a problem I have only seen this a couple of times
        Your unit should work fine with it
        • petehall347
          • Jan 2015
          • 4432
          • United Kingdom
          recycle the charge fully 3 times and see what happens.
          • clearchris
            • Dec 2013
            • 687
            So far, so good. It's reading 94% charged, which is better than the 70% charged the old batteries would show. I don't know that it will ever be fully cycled, it gets used for a few minutes and put back on the charger. I could leave it off the charger for a few weeks, if you guys think that it would be helpful to fully cycle it.
            I put double sided tape on the top to stick it to the top case and same tape on the bottom to protect the battery in case it gets loose. There was a lot of room left, I could have easily used a larger battery.
            Overall, this was a pretty easy fix. The case came apart with a plastic pry tool, there was no breakage, the clips seemed stout. I cut the batteries off with some side cutters so I could use as much heat as needed to remove the tabs from the board.
            We'll see how this battery holds up.
            Thanks to everyone!
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Good to hear it's working. As a bonus, you also have a slightly upgraded capacity from before as well (1x 850 mA battery vs. the old 2x 320 mA, which didn't even charge fully).
                • Jul 2011
                • 6057
                What is your voltage when it says 94 % this might be a problem with having two protection board on the unit if your voltage to the battery is 4.2-something you’ll be alright you just have to remember that when it says 94% mean that it fully changed
                • clearchris
                  • Dec 2013
                  • 687
                  Yep. IIRC, I have never seen it at 100% even when new. I checked yesterday and it read 97%. I don't ever believe the stated rating, but my new no-name battery probably does have more mA vs the original no-name batteries.
                  I'll probably have to swap them out again in a year or two, at that time, I'll see what the biggest battery I can fit in there is. It's kind of overkill though, it lives on the charger, gets taken off for 5 minutes and goes back on the charger.
                  • clearchris
                    • Dec 2013
                    • 687
                    What is your voltage when it says 94 % this might be a problem with having two protection board on the unit if your voltage to the battery is 4.2-something you'll be alright you just have to remember that when it says 94% mean that it fully changed
                    It could be, though from the spec sheets I read, these chips have very little draw. I did later get a reading of 97%, so I'm optimistic about that.
                    Not sure what the voltage is, but the 70% charged batteries were at 4.1v, which was surprising to me, I wouldn't have thought that from 4.2v to 4.1v was a 30% drop, but I haven't reseached the voltage drop curve of li-ion batteries.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Ah, that's a good way to kill your Lithium batteries - keeping them close to 100% charged all the time.
                      If you want your batteries to last, keep them between 25% and 75% most of the time, and only fully charge when needed.
                        • Jul 2011
                        • 6057
                        I am not surprised by your results the battery charger that I have show the same type results and most cell phone battery backup have the same type of results
                        I try not to run down a lin-ion battery below 40% very often I find that the batteries do not seem to last as long as when they are new
                        • clearchris
                          • Dec 2013
                          • 687
                          That presents quite the conundrum. The device doesn't function well at around 70% battery or lower. I don't think it deals well with the voltage sag. The bluetooth connection barely works, I have to hold the phone within 6 inches of the device.
                          So I guess I'm back to leaving it on the charger and replacing every few years. Maybe a larger battery would work better, it would be able to have higher voltage for longer, and I could leave it off the charger.
                          sam_sam_sam:
                          Yeah, I guess the batteries stay high voltage for longer, and then lose voltage quickly. I assumed a more linear voltage drop during discharge.
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            Sounds like it was designed for a 3.6V Ni-Cd or Ni-MH battery pack (3x 1.2V cells, which normally come out to around 4.4V charged) or perhaps even a 4.8V pack (about 5.8V when fully charged).
                            I suppose there isn't much you can do then. For a moment, I thought perhaps a cheap boost converter in there would do the trick. But with that running all the time, this will drain the battery by itself too. Battery charge also won't last as long due to some efficiency lost in the converter. So that's probably a no-go either.
                            • tommyb1987
                              • Jun 2022
                              Thanks to everyone!
                              just wanted to stop in to say thanks, 4 years on and this post helped me do the same thing for my old chisel that wont charge. back to working!
                              • brispuss
                                Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                                by brispuss
                                Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                                Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                                I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                                12-28-2022, 02:58 AM
                              • howardc64
                                Where do repair shops buy MB replacement batteries?
                                by howardc64
                                Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                                Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                                BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                                07-25-2024, 10:42 AM
                              • carrzkiss
                                Cyberpower cps1500avr not charging batteries
                                by carrzkiss
                                Hello, all.
                                Cyberpower Battery Backup Unit.
                                I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                Checking the voltage, it was down to 22v.
                                I quickly removed everything...
                                06-15-2024, 02:10 PM
                              • dicky96
                                HP Laptop TPN-C125 replacement batteries will not charge after 12 months
                                by dicky96
                                I got four replacement batteries for these HP laptops about a year ago. The originals would not charge, and these replacements have now gone the same way.
                                I'm not sure what the expected life of a laptop battery is but I woud have thought they would last longer than that
                                I now need to order four more batteries. Possibly these replacement ones were now good? The owner does not mind paying a bit more for originals or good compatible batteries that last longer
                                The top one is the original
                                Any ideas?
                                Cheers...
                                05-19-2021, 07:53 AM
                                MSI Infinite A VR7RC-003DE + Gaming Pack Infinite i5-7400 Specification for Upgrade or Repair
                                This specification for the MSI Infinite A VR7RC-003DE + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A VR7RC-003DE + Gaming Pack boardview and Infinite A VR7RC-003DE + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                09-12-2024, 03:28 PM
