CoolIT ECO II-120R pump failure
  • alindumitru46
    • Aug 2015
    • 255
    • Romania
    I have an AIO ECO II-120R from CoolIT for about 5 years that suddenly yielded. The temperature rose instantly to over 100 degrees Celsius, the cpu went into the throttle and shut down. It was received ast RMA from the previous model, a Coolit ECO A.L.C. 120 who suffered the same symptoms.
    There is no vibration when checking the pump on the power header fan, and no fan movement is detected in the bios or in the monitoring programs.
    Because I do not think there is a protection of the IC that controls the pump, it may have been ceded or, due to liquid loss, the pump has caught air and the IC has burned.
    What are the chances of repairing this toy? Can I replace the IC only?
    For example Laing DDC pumps has a custom pcb for DIY with a more reliable controller: https://www.diyinhk.com/shop/ddc-pum...ed-mcp350.html
  • redwire
    • 3912
    Re: CoolIT ECO II-120R pump failure
    Is the Hall sensor IC U2 burnt and cracked? It kinda looks like that.
    LB11961 motor driver IC might have died (shorted) and then killed the Hall sensor.
    • alindumitru46
      • Aug 2015
      • 255
      • Romania
      I am convinced that the IC controller is affected (unfortunately only monday I can do measurements on pcb), but U2 is a free place there. It seems rather the place of a coil that has never been mounted.
      Now I read that this LB11961 IC has a "Built-in thermal shutdown circuit" who has not done his job very well. Maybe the "Hall sensor" has never been mounted for low cost policy, actually ...
      • alindumitru46
        • Aug 2015
        • 255
        • Romania
        Ok, I did some research and here's what I discovered, using the second pump(from the first AIO), which is identical.
        - both pcb are identical.
        - there is the HALL sensor, mounted under the pcb on the U2 position.
        But how to make measurements on controller LB11961 ?! I read the datasheet but if I am powering up there is no risk of something burning?
        But Hall sensor how to check it? I think my humble knowledge is already out there
          • 31294
          did you check the motor winding?
          • alindumitru46
            • Aug 2015
            • 255
            • Romania
            If you mean winding, it gives continuity.
            I understand that checking in idle (or even the presence of air in the plant) can cause the controller to burn, and I'm afraid to do checking under voltage without having an advised opinion.
            • redwire
              • 3912
              I would make sure the pump rotor is not stuck, that nothing is wrong with the mechanical- bearings, impeller etc.
              The motor IC can operate from 4.5-16V so try run the pump dry with a lower voltage power supply.
              Add a large capacitor >220uF to the power supply, to absorb back-EMF overvoltage spikes so they do not damage the IC.
              I think 7V or so is the lowest that allows the internal 6V regulator 6VREG to work.
              I still do not like the hall sensor picture, it looks cracked. All its voltages should be close to HB pin 1.3V. You can check the 6VREG too. Make sure the motor leads L1, L2 are not shorting to nearby PCB traces.
              There's not much here to troubleshoot, it's all one big IC and a sensor and a motor.
              • alindumitru46
                • Aug 2015
                • 255
                • Romania
                Ok, good to know.
                I'll try tomorrow morning, it's almost midnight on me now
                Thanks for tips.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Agreed.
                  Check the mechanical bits first. Then we can go troubleshooting the electronics side of things, if needed.
                  I received two PS3 140 mm fans many years ago that were both plugged into a household 120V AC (US) outlet, and they both had completely damaged driving MOSFETs. The hall sensor in both, however, was fine (even though one of these fans had a completely shorted controller as well). Given that the controller on your pump motor also has the MOSFETs integrated in it, I would suspect that this is what's wrong with the pump and not the hall sensor, if everything on the mechanical side of things checks out fine.
                  That said, here's the thread of the two PS3 fans mentioned above, in case you're interested in a long (and somewhat pointless but also fun) repair. Yes, they both work now!
                  https://www.badcaps.net/forum/showthread.php?t=63464
                  • alindumitru46
                    • Aug 2015
                    • 255
                    • Romania
                    Mechanical problems do not seem to be, but I'm afraid to disassemble the pump assembly now. I have a similar system, previous model, but I have not been able to assure tightness after disassembly, decalcification and refill.
                    I read your adventure. Congratulations on the results, it was a great headache. I have to deepen some aspects, though.
                    • npielawski
                      MacBook Pro late 2016 (820-00239) with multiple failure modes.
                      by npielawski
                      I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                      I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                      10-15-2025, 01:53 AM
                    • puccovelli
                      Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
                      by puccovelli
                      Hi all, I hope this is the right place to post.
                      I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
                      I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
                      1] Could someone confirm what the component that has blow actually is (and where I could get another from).
                      2] Whether this component is likely to cause the RAM failure issue, and if replacing...
                      10-11-2025, 06:30 AM
                    • Sus256
                      HISENSE 65E7KQ PRO - no boot
                      by Sus256
                      Hi all!
                      HISENSE 65E7KQ PRO
                      RSAG7.820.13512 - chassis
                      MT9618BAATAB - cpu
                      RSAG7.820.12059 - power
                      HD650Y3U77 - panel
                      KLM8G1GETF - emmc
                      The TV does not turn on, the standby indicator is on. All voltages are present.
                      Emms is dead. Not readable, not detected.
                      Replaced emmc.
                      But with another dump there is no launch
                      Terminal log
                      UART
                      AC_ON
                      RPMB key is not yet programmed
                      HASH1_VERSION=0x00000000 64bit
                      E-B
                      FDE enabled
                      layout pattern onebin by SAR7,0...
                      06-01-2025, 02:11 AM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • ctroxtell
                      Carrier HK50AA063 display controller common failure help
                      by ctroxtell
                      I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                      02-05-2025, 05:31 PM
