Egg turner
  • Lapwing
    • Feb 2015
    • 40
    Egg turner
    A mate has this egg turner/incubator thing. Part of it has never worked. It has a toggle switch "Level" - "Off" - "Turn"
    The part that has never worked is the "Level" bit, apparently this is meant to speed the motor up so that the egg trays can be removed, you still have to wait and stop the motor manually when the trays are level, as it is now he has to wait hours (Turn position) for the trays to get to where he can get them out.
    A few pics he sent me.
  • redwire
    • 3912
    Re: Egg turner
    It looks like a gear-reduction synchronous motor (one speed, non-reversible) that regularily moves the egg trays back and forth, mechanically.
    Not a lot you can do with that and only two motor wires.
    In the pics, motor wiring at the switch is violet+orange, but at the motor is red+grey. Follow the wires on the "Level" switch contact, should go to something interesting or nothing at all.
    It originally might have used a different type of motor.
    • Lapwing
      • Feb 2015
      • 40
      Re: Egg turner
      From the switch the wires just connect to each other via a standard block mounted to the roof of the box.
      The synchronous motors i have seen on youtube that connect via a toggle switch like this are for "reverse - off - forward".
      When the switch is in the "level" position the motor stops. He has swapped the connections on the switch to eliminate the switch from being at fault.
      • Lapwing
        • Feb 2015
        • 40
        Re: Egg turner
        Hmmmm looking at that picture, the violet wire is at a funny angle to be connected in that block, don't you think ?
        • Lapwing
          • Feb 2015
          • 40
          Re: Egg turner
          Good spot on the colour change redwire, i didn't notice that, i must go to specsavers one day and get my eyes tested LOL
          So now we are getting somewhere, the Violet wire from the switch has been cut ! He can see the end of it hidden in the middle of the wires (cable tied together).
          So i bet you are correct about the motor being changed too redwire.
          Cheers
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            Re: Egg turner
            Cheers
            Have you Ohmed out the purple wire to the motor. By the photo it seems like it might be broken inside the insulation at the bottom bend.
              Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
              This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-06-2024, 05:30 AM
            • G0RIT
              Reebok one GT40s treadmill lift motor runs at switch on
              by G0RIT
              Good evening I am working on a Reebok oneGT40s treadmill. It had a flashing display which the replacement of D3 rectified. However the lift motor now runs when the mains is turned on and does not stop. If I then select start so the tread motor runs and disconnect the up lead to the lift motor it stops. If I then reconnect the lead the lift motor works as it should with the controls. It will continue to work correctly until the mains is turned off and on again, or the safety device is removed and replaced. It then runs again and only by disconnecting and reconnecting the up lead will it operate...
              06-23-2022, 05:57 PM
            • Natob82
              Micro Momentary Push Switch?
              by Natob82
              Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
              12-21-2022, 05:22 AM
            • grimacelord
              NEC TurboExpress On/Off Power Switch Replacement Help
              by grimacelord
              I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
              I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
              I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
              11-09-2023, 09:49 AM
            • SluggerB
              Help making a switch work the opposite way with a relay
              by SluggerB
              I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
              I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
              It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
              02-07-2025, 07:57 PM
