Original Xbox SATA Adaptor
  • NeMesiS34
    • Sep 2015
    • 37
    Well I've been upgrading some original xbox consoles with new sata drives.
    I bought a dozen of these sata adaptors from china...
    The good news is that they are cheap and compatible with the console.
    Bad news is that the human side of the manufacturing of these adaptors are quiet poor.
    Alotta of the solder on the pins look very dry so I usually fix it up..
    The two caps on the board are 470uf 25v (8x16mm) "Chong" branded cheap chinese crap.
    I've been using GP caps from a local electronic store but they overcharge too much.
    So I've been looking for a better alternative...
    At the moment I've been contemplating between:
    Rubycon FLJ 470uf 25v (8*16mm), or
    Nichicon HE 470uf 25v (8*20mm)
    I havnt chosen these caps for any particular reason other than physical size and availability.
    I'm interested in other peoples thoughts...
  • mariushm
    • May 2011
    • 3799
    Re: Original Xbox SATA Adaptor
    You don't need very low esr capacitors super high quality capacitors for those 470uF 25v ones, they're not in a high frequency switching regulator circuit where low esr would matter.
    And, you can probably manage with only 16v rated capacitors, since the hard drives work with 12v and 5v, so i sincerely doubt there's voltages higher than 12v on the board.
    Any good brand capacitor will probably do.
      • 31090
      i hope your upgrading the cables to ata133 type 80pin ones.
      • NeMesiS34
        • Sep 2015
        • 37
        Sweet as...
        Yea, actually some of the adaptors have 16v caps...
        Thanks again, I found some 470uf 16v Rubycon ZLH (8*16mm)
        Yea, definitely am... Cheers
        • mockingbird
          • Dec 2008
          • 5484
          Where did you see Rubycon FLJ? Haven't heard of that series...
          Also, an 80-pin cable probably won't add anything.
          Those adapters limit the device to UDMA2 (JM20330 Chip).
            • 31090
            the xbox has ata66 chipset, but a cheapass m$ 40pin cable.
            if you fit an 80pin cable the drive does run faster - a lot faster.
            • NeMesiS34
              • Sep 2015
              • 37
              ZLJ Sorry...
              And yes the cable makes a difference, It tried without and it just caused me so many problems. If you have Premium you will see the difference there as the animations will run alot smoother...
              • DynaxSC
                GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                by DynaxSC
                I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                The board is generally working now, all PCIe ports are working, Windows installs normally.
                However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                03-10-2025, 12:27 PM
              • ohren
                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                by ohren
                Hello!
                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                Measured voltages with no load:
                After rectifier diodes
                12V: 6.17 V
                5V: 5.67 V
                Secondary transformer pins AC measurement (really don't know if this says anything)
                12V: 2-2.5 V
                5V: 1.04 V
                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                03-18-2023, 10:33 AM
              • tccyo22
                Xbox One Original missing 12v enable signal
                by tccyo22
                Hi there, I have an Xbox One original in which I have all the 1.8v, 3.3v and 5.0v standby power rails present, however my 12v rail is not turning on and the enable signal PSU_V12P0_EN from the SMC to turn the power supply on is missing. There is high resistance on this line so it's not shorted directly to ground which leaves me with not many options.
                Was looking at a schematic and see the enable is created by the SMC. I have 3.3v on SMC_RST_N_IN but I'm a little stuck on where to look next. Is it likely that the SMC has gone bad or am I missing something else (it's my first time with...
                08-14-2023, 06:06 AM
              • bulkchart32
                does anyone have a schemtaic for what circuit each cap is in on the original xbox?
                by bulkchart32
                i have a 1.1v and i am having issues with faint wavy lines on the screen that i am trying to make perfect so it will be my main xbox.. also have some 1.0v's that are doing it but to a lesser degree. i really don't want to do a full board recap, especially don't want to have to replace those smds, so i want to find which specific caps that filter the video signal. i have already replaced several caps and messed up one of them that caused a dead short(has been repaired). so i really don't want to just do all the caps. plus, those 1.1v boards have a lot of them. i'd really like to just focus on the...
                05-16-2025, 07:33 PM
              • bulkchart32
                are these caps good for replacing the ones in front of the cpu/gpu on an original xbox?
                by bulkchart32
                nichicon
                1500 µF 16 V Aluminum - Polymer Capacitors Radial, Can 8mOhm 2000 Hrs @ 105°C
                are what​ i used because i had heard the voltage doesn't matter as long as it is more than the original cap. i'm now reading that high voltage may make the cap's esr too high. is this a good cap for replacing those oem ones?
                05-14-2025, 02:12 PM
