Nikon Coolpix - bad caps ?
  • cosmicray
    • Mar 2015
    I have several older Nikon CoolPix cameras. All of these cameras are powered by 2xAA NiMh batteries. One is a E4600, which I purcahsed new in 2005, and use it extensively (possibly over 50k shutter clicks). It has had batteries installed almost continuously over the years. This camera I have no issues with.
    About 4 years ago, I picked up a used E4600 off craigslist, mostly as a backup in case the primary camera dies some day. The replacement E4600 does not hold settings very well when swapping batteries.
    A few months back, I picked up a E7600 at a flea market. It works fine, other than it dumps settings immediately after removing the batteries.
    The original E4600 camera does fine about keeping its settings when swapping or charging batteries.
    As all of these cameras were manufactured in the 2005/2006 time frame, could the problem with dropping settings be the result of caps going bad ?
    I have replaced caps in a Dell monitor from that era, but I am initially hesitant about taking a small pocket camera apart to go look for the caps.
    Any thoughts ?
    TIA
  • alindumitru46
    • Aug 2015
    • 255
    Re: Nikon Coolpix - bad caps ?
    Be careful, the capacitors can be very similar with AG-2 batteries types but hard to find.
    I have a Kodak Z8612IS with same simptoms. After disassemble, I found a oxidized Shoei-Taiyo Yuden PAS414HR-VA5R capacitor.
    I barely managed to order ipcs from a Chinese website, he arrived a week ago but I had no time/mood to replace it and check if it fixes the problem with keeping the date and settings.
    • carrzkiss
      Cyberpower cps1500avr not charging batteries
      by carrzkiss
      Hello, all.
      Cyberpower Battery Backup Unit.
      I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
      When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
      In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
      Checking the voltage, it was down to 22v.
      I quickly removed everything...
      06-15-2024, 02:10 PM
    • RetroComputingGrotto
      New Toy UNI-T UTi260B - What Settings?
      by RetroComputingGrotto
      I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
      After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
      I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
      09-02-2025, 08:36 AM
    • howardc64
      Where do repair shops buy MB replacement batteries?
      by howardc64
      Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
      Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
      BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
      07-25-2024, 10:42 AM
    • arpii
      Nikon Coolpix P520 - Not working properly | Short
      by arpii
      I got a Nikon Coolpix P520 in a defective condition, few weeks ago. The battery is a 3.7V 1000mA Li-Ion battery, it was almost completely discharged.
      The symptons (back in time):
      -Not starting
      -Not charging
      Disassembled, then found few things. There was a short on the line of the battery feed rail and the USB charger port's fuse was also wrong.
      Fed 3.7V to the battery line with a bench PS and a small ceramic capacitor warmed up next to the battery positive point. Just removed this cap and confirmed, it was bad. There is no...
      11-23-2021, 09:22 AM
    • Astonished
      Fixing the Charge Circuit of the Batteries of the DC Motor
      by Astonished
      Hi friends of electronics
      What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
      The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
      Please help me fix this circuit.
      (the datasheet of the IC: https://pdf.datasheet.live/28...
      01-28-2025, 06:24 AM
