Frist generation PS3 YOLD repair from wrong to right
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8221
    Well, we got a given to us first gen PS3 with the YOLD problem. Here is my rant for the day.
    The original owner had sent this PS3 into a supposed to be service shop (non Sony) that even warrantied their work for 90 days or something like that. Over the years he had sent it in twice to get the GPU reflowed. After it broke shortly after again, he gave up and bought another one. So here on my bench the poor old thing is. Sorry, I have no pics, as the PS3 is repaired by now and working. I found that reflowing must be some sort of art and some just can't do it and should not.
    The silver heat paste was caked on to the CPU and GPU so hard, it took me 30mins to get it off with 99% alcohol to get down to the shiny metal. 8 swabs and one paper towel full later. Next thing the flux. There was flux that hardened up in such a way that 99% alcohol couldn't get it off using a toothbrush. It still was underneath the CPU and GPU too. What a mess... what a mess... that was a poor reflow job and charged quite a bit of money for it.
    I won't go into great detail on how exactly I fixed it, as there are very good guides on the internet already even permanent fix for the 1st gens. Preheating the board on both sides, using quality flux and remember to cool the board slowly down is key. Also clean off the old flux form the board. I had to get all that old stuff out form underneath the CPU and GPU too. It was almost like dark yellowish brown pork lard!
    That is what I call an utter crap job that some tech had done. I won't post Name or Phone number (the warranty void sticker with name and number is still on the PS3). However I do say that much, that the location of them is in the City of Nova Scotia.
    Is it really that hard to ask for a proper repair, if someone spends like 100$ each time to get it repaired?
  • chth96
    Is it good to use chemistronic flux off es835b for flux remover?
    by chth96
    I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
    Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
    11-17-2023, 07:25 AM
    Multifix 425-01 and 450-01 Rework Flux Datasheet
    REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
    - No Clean Formulations
    - Low residue
    - Range of activity to deal with different component solderability
    - Halide free
    - Suitable for dispensing
    - Compatible with solder coatings and/or No Clean flux cored solder wire product range
    Both products are supplied in syringes or cartridges for application by dispensing....
    10-07-2024, 06:02 AM
  • evilkitty
    Flux causing high resistance short?
    by evilkitty
    Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
    Temp is on the left humidity is on the right
    i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
    The pin out looking down from the top is (note this is common cathode)...
    07-17-2024, 09:38 AM
  • chth96
    How can I remove flux with the smallest rubbing?
    by chth96
    I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
    Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine​​
    Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
    Is there any way to remove flux with the smallest rubbing or without any rubbing?
    Any reply would be appreciated.
    11-24-2023, 05:22 PM
  • Jeff'sTech
    Dell Latitude 7420 BIOS Unlock Gone Wrong
    by Jeff'sTech
    Hello everyone.
    I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
    11-08-2023, 03:30 PM
