ps3 hdmi problem
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    ps3 hdmi problem
    I there guys , i received another console , client was complaining about not getting into system , we rebuilded database , and it start going to system , but we noticed somethimes on hdmi , signal would be lost and only av would be working . so we reinstaled frmware , and i been playing for like 3 days , always omn hdmi , with no problem . client took it home , and came back today , saying its doing the same shit , on hdmi sudently lost signal . and only av is working .
    RSX problem ? meanwhile i opened it , and cheked all soldereds on the hdmi port , and resoldered in case could be a cold joint or something , but nop .. problem persist
    never had this issue .
    i had some previous one that HDMI was not working at all ..
    this is the model with the black plastic PSU.
    any toughs are apreciated.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: ps3 hdmi problem
    Yes that would be the RSX at fault most likely.
    A working TV? How boring!
    • highpulse
      i hate HP
      • May 2013
      • 1490
      • portugal
      well i was thinking on that , but was thinking with a bit of luck , would not be the RSX problem .. unfortunetly , well , will mention to him about reballing ... but i wouldn't bother much for that , this chip is dieing thats for sure , and new RSX chip , never found and i will never found , will advise him to buy a new one .
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        You need replace Sil IC or Panasonic IC MN.....
        • xboxhaxorz
          • Jan 2011
          • 196
          it could be the rsx which is the cause of 99% of issues, the hdmi uses more power so if the solder balls are brittle then it wont work but a/v still works fine as its not high def
          • highpulse
            i hate HP
            • May 2013
            • 1490
            • portugal
            well , the weird thing is that this shit was happening before system reinstall . after that i played COD ghost entire campaign during 3 days ,, playing a bit pause , playing a bit pause , since i cannot stay all day long playing , im in a lab of a shop :P .. so all was good , and now again same issue . i thinked on the UPconverter hdmi IC , but seems strange to be this ic , sounds a RSX .. but fuck i hate this , when we cannot conclude a malfunctions without a good measure teory , instead of reworking chipset .. :S frustrating.
            • eltunisie
              Hdmi problem in dell insprion 3521
              by eltunisie
              i have dell insprion 3521
              hdmi port it can good work but now not disply alot of screen and i used convert hdmi to vga but not work
              i tray
              windows 7, windows 10, orginal vga drivers from dell, update bios
              i found 5v on th e socket
              what a problem?...
              11-06-2025, 06:24 AM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • redwire
              Onkyo TX-SR607 HDMI problem showing a black screen intermittently
              by redwire
              Onkyo TX-SR607 HDMI problem showing a black screen intermittently, audio was OK.
              It would usually cut out a few minutes after power on, for maybe 1 minute then work OK, then cut out and go to black again. Or fade out to sparkles and noisy video.
              Well known is these boards need recapping and there is a strange mix of parts on both sides of the board.
              The bottom of the board has 100uF 4V (5.3*5.3mm, qty 5) and 220uF 4V (6.6*6.6mm, qty 5).
              Per the service bulletin, an issue is the Toshiba LDO's want low ESR for stability so I went with 100uF 6.3V polymer...
              11-16-2023, 08:56 PM
            • Pakamalu Flia
              Smd Capacitor lost in PS4 Fat CUH 1215a - Hdmi Line
              by Pakamalu Flia
              Good morning team
              I turn to you for help. A client brought me a Ps4 fat model CUH1215a.
              Motherboard model: SAC 00-1 1-980-066-31.
              Diagnosis: The customer mentioned that the PS4 fell on the floor while his children were playing.
              It turns on but does not give an image.
              Power Supply: Ok -5 and 12 v line
              The HDMI connector and its solders were checked. Everything ok.
              Visual inspection of the motherboard shows the existence of a capacitor? absent in this part of the mother
              My question is, will anyone...
              08-02-2024, 11:50 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
