PS5 identity component
  • abblanco
    • Jul 2010
    • 7
    • Spain
    Hi need remplace this component with reference 504X.
    Have 5, 2 and 0,4 voltage.
  • LaPCon_IT
    • Sep 2022
    • 82
    • Malta
    https://www.aliexpress.com/item/1005006056722070.html
    It is BD3512MUV probably.
    • abblanco
      • Jul 2010
      • 7
      • Spain
      Tank you, i can buy this item. The 504x is a 5v regulator and have 8 pins only.
      Thank you for your help.
      • volinakis
        HP 830 G10 Bios Identity Data Recovered while unlocking
        by volinakis
        Hi, I need some help with HP EliteBook 830 G10
        S/N: 5CG3444X0X
        ProdID: 8Z5G7EC
        Can't find motherboard ID, SPS is N44544-601
        I am trying to unlock it, did all modifications in main bios to put it in MPM mode, after writing new bios at 1st boot it appears a message:
        "Bios Identity Data Recovered
        The Bios has recovered its identity data from Embedded Controller due to data mismatch"
        and it won't start in MPM Mode. Someone please help me to disable this "Bios Identity Data Recovery", I don't have a clue where it is.
        Attached...
        08-05-2024, 09:48 AM
      • speaktorob
        Reference Nvidia GTX 980 ti - looking for a new shroud
        by speaktorob
        So a while back, to deal with the fan noise of the old blower style shrouds on the reference cards, I chucked it and installed the monster that is a Raijintek MORPHEUS 8069, with a couple Noctuas on it. Did the job but quite unwieldy tbh.
        Anyone know which boards would have a compatible shroud for it? I know the EVGA used the reference board but wondering if any other manufacturers did. I want to put something sensible back on it, but I'm having a hard time getting hold of even a faulty reference board for a reasonable price.
        03-22-2024, 03:00 AM
      • Rhork
        Chip reference DA0G7BMB6D0 rév D HP Pavilion - 15-cs0006nf
        by Rhork
        I would like to know the reference of a QFN-20 because the reference marked on the chip does not give anything...
        PC Reference : HP Pavilion - 15-cs0006nf
        Motherboard : DA0G7BMB6D0 rev D
        Reference marked on the chip: AWVAIL
        Type : QFN-20
        I didn't find a boardview or repair schematics
        Thanks in advance...
        03-30-2022, 11:32 AM
      • Francesc V.
        Diode marked as "E57".........not able to find it by reference
        by Francesc V.
        Hi:
        I have what it might seem a zener diode. It's marked as E57, but I haven't found any reference that might match my observations.
        I've took one from the same circuit and tested isolated with the power supply and a 1k resistor. with 10V, the possible zener stays at 6.6V.
        It seems a SOD123 package. It measures (2.6mm x 1.6 mm).
        Any idea? it's a 6.6V zener?
        06-14-2025, 09:56 AM
      • hakuuart
        Error E4 of HP Smart Tank 750 printer
        by hakuuart
        Hello everyone, I need some help or advice regarding the HP Smart Tank 750 device. I have already checked for paper jams and anything stuck inside, as well as all the flex cables, but I still encounter an E4 error. We have taken it to customer service for inspection, but they don't know how to fix it. Is it possible that the issue lies with the main board or the sensor? I would really appreciate any guidance from those who have experienced this problem. Thank you!...
        05-12-2025, 08:51 AM
