ps4 power supply
  • ut-norm
    • Nov 2019
    • 67
    • italia
    ps4 power supply
    Hi, I need to replace the power supply of a PS4 mod. N14-240P1A that isn't working. I found one mod. ADP-240AR AA from a PS4 fat. I'd like to try replacing them by inverting the pins of the connector that goes to the motherboard, the first has 4 pins, the second 5, but that's not the problem, they can be adapted. Only the N14-240P1A has the first pin marked ACIN_DET where 4.7v are present. The ADP-240AR AA doesn't. To enable the 12v on the N14 -240P1A, short-circuit the ACIN_DET pin with ACDC_STBY, while on the ADP-240 AR, short-circuit ACDC_STBY with the 5 volts SB. I don't know if these two cards can be interchanged. Thanks for your help.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
    07-01-2024, 06:34 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
