Unknown Components
  • mecmast
    • Jun 2021
    • 19
    • Cyprus
    Unknown Components
    I've a pcb with two unknown components. I'm adding photos. Would you please help me what are the components are?
  • mecmast
    • Jun 2021
    • 19
    • Cyprus
    I have showed them up in blue circles
      • 21986
      Looks to me like a sensor of some kind. What is this board from
      • mecmast
        • Jun 2021
        • 19
        • Cyprus
        It is from a fiber production machine. There is a hole between two components. There goes fiber line. When the fiber/rope ends or breaks, the sensor activates.
        • Sam Scarbo
          Sparkle 1200W PSU MAGNA Model: SPM1200AXJ8 - Broken. Need help identifying components. Any schematics available?
          by Sam Scarbo
          My Sparkle (SPI) PC power supply has broken. Originally, there was totally no power output. The 5V-standby was not there. I have replaced a few bulged capacitors but not helping.
          I was trying to do more troubleshooting but burned more components. Some got burned so badly that the markings were gone. And also, the markings of a few transistors were gone because the component surface was worn out somehow.
          If you happened to have disassembled the same PSU model, please help to provide the markings of some of these components.
          See the attached two pictures of the small...
          09-18-2024, 08:29 AM
        • slap_happy
          Help identify components from blurry FCC photos?
          by slap_happy
          The first photo is of my sample device which lacks the two components that I wish to identify.
          The second (very blurry) photo is of the same model device submitted to the FCC, which does contain the two components I wish to identify.
          The board for the device is configured for a USB 2.0 A port, but the port is not installed at the factory. But it does work if installed.
          However, the power pin does not supply voltage because the two components in question are not installed in produced units.
          One of the two components (6C6) is obviously a capacitor....
          01-24-2022, 01:06 AM
        • User2025
          Please help to identify the components on Surface Laptop GO3, model 2013, i5-1230U
          by User2025
          I am working on a Surface Laptop GO 3, which is the new release 2024 with a i5-1230U processor. Originally, it had a 256GB SSD, then the owner attempted to upgrade it to 1TB SSD by himself. "Surprisingly", it did not boot afterwards, then changed back to the original SSD, did not boot either.
          It turned out to be that just a couple of components had been knocked off when the owner was trying to get off the SSD cover with his beloved screw driver.
          I do not have another board of same model. Although I have a Laptop Go 2, the layout of that bit...
          04-29-2025, 04:13 PM
        • araxnido
          Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
          by araxnido
          Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
          When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
          06-10-2025, 09:26 PM
        • summerwhite
          DJI Mini Pro 3 missing components near camera connector
          by summerwhite
          I have a DJI drone that is not displaying a video feed anymore after a repair.
          When tearing down the DJI drone to fix the armature there was some hot glue next to the camera connector that i had to remove.
          Now there are missing components either because they got pulled off or because they where never placed.
          I have two reference images from XXZ and a photo of mine.
          I'm truely hoping someone has another DJI Mini Pro 3 that they can help me identify what these components are and if they are necessary.
          On the board view from XXZ they...
          04-06-2025, 11:15 PM
