Anyone here tried the ps2 slim resurrector ide hack ?
  • PedroGG90
    بدر الدين
    • Feb 2023
    • 30
    • Morocco
    Hello.
    This hack basically makes ps2 slim 7000x models able to load games via hdd like the ps2 fat with its hdd adapter via HD loader.
    So I want to know if someone did this and how is the compatibility and all that ?
    Here are the public pinouts on the motherboard
  • foxer
    • Feb 2022
    • 15
    • us
    Re: Anyone here tried the ps2 slim resurrector ide hack ?
    I did.
    Compatibility is perfect. Have not had a problem in 8 years.
    The soldering is a bit of a hassle, the space between the points on those resistor arrays is extremely narrow, and the leads on the resistors are somewhat easily broken off, so a good job means adhering the wires to the board before soldering so they aren't flopping around and yanking on the leads. And if the hard drive is going inside the ps2, not sitting outside it, then the wiring gets difficult and needs to be arranged (and glued down) inside in such a way that there's very little overlapping of wires, whether with each other or with board components, because space in the ps2 is tight and loosely cramming 28 wires into the back won't work. It also takes chopping the shielding in half, see mine in the pic below. Using a sata hdd is probably more difficult. I had a japanese webpage bookmarked that shows an internal sata hdd and its adapter. http://vaot.mydns.jp/fc/SsdInPS2.htm
    • PedroGG90
      بدر الدين
      • Feb 2023
      • 30
      • Morocco
      Originally posted by foxer
      I did.
      OK that is good to know , because back in the days this was a dream for slim owners ( a console that has the same hdd functionality as a fat )
      Insulated copper wire will do the job i think !
      What size do you think will be safe for soldering on those resistors ?
        • 30919
        is it faster than the usb interface?
        • foxer
          • Feb 2022
          • 15
          • us
          I don't know wire gauges, sorry, but they need to be a very small size.
          It's faster than running a game disc.
          • Dan81
            SNES-powered
            • Oct 2013
            • 1865
            • Romania
            Yes, as the points are basically the direct IDE signals found in the expansion port on phats.
            30 AWG Kynar wire should be enough. Most people use it for PS2 chips.
            Main rig:
            Gigabyte B75M-D3H
            Core i5-3470 3.60GHz
            16GB DDR3-1600
            Samsung SH-224AB DVD-RW
            Delux MG760 case
              • 30919
              if i was going to do this, i would get a 44pin IDE to SATA adapter board and remove the connectors and wire that inside.
              i did that with a dreamcast - had an ESATA connector screwed to the back of the case
              • PedroGG90
                بدر الدين
                • Feb 2023
                • 30
                • Morocco
                Thanks.
                Since the ps2 input is ide , Isn't it the reverse ? Sata to ide ?
                  • 30919
                  descriptions vary,
                  it's the board to use a sata drive in an old laptop or something - very cheap on ebay.
                  i paid about $4 for one
                  the ESATA cable cost more than the board!
                  • PedroGG90
                    بدر الدين
                    • Feb 2023
                    • 30
                    • Morocco
                    descriptions vary,
                    Sounds good if it allows more than 128 gb .
                    Please share the model you bought .
                      • 30919
                      the cheap ones have no model,
                      just look for one with a marvel chip or a j-micron chip.
                      they are better than sunplus ones
                      • PedroGG90
                        بدر الدين
                        • Feb 2023
                        • 30
                        • Morocco
                        Thanks man .
                        Now all i need is some motivation to do the wiring
                        • foxer
                          • Feb 2022
                          • 15
                          • us
                          some motivation
                          chugging a whole pot of coffee works for me
                          • PedroGG90
                            بدر الدين
                            • Feb 2023
                            • 30
                            • Morocco
                            The moment of truth.
                            It feels great to play ps2 the right way after all these years.
                            • dmill89
                              • Dec 2011
                              • 2531
                              Yes, especially since the USB ports on the PS2 are USB1.1 which tops out at 12 Mbps (1.5 MB/s) so ATA/66 (66 MB/s) is a rocket ship by comparison and much faster than the DVD drive (5.28 MB/s) as well.
                              X2, though I went the "easy" route with a "Fat" PS2 (SCPH39001)
                                • 30919
                                that's just flexing!
                                next you need a sata version of the adapter and a bigger drive
                                • PedroGG90
                                  بدر الدين
                                  • Feb 2023
                                  • 30
                                  • Morocco
                                  Good for u , fats are the easiest but rare nowadays .
                                  Even the slim I got is beat up and has no dvd drive or screws.
                                  Time to resurrect some dead bodies.
                                  • dmill89
                                    • Dec 2011
                                    • 2531
                                    I know availability varies worldwide, though since only the first generation of slims support the IDE HDD mod (as later variants removed the components that supported IDE connectivity all together rather than just omitting the connector) and these models were only produced for a little over a year (2004-2005), at least in the US it is generally easier to find "Fat" models (often with a dead DVD drive but that doesn't matter if you're only going to run games off the HDD) than this small subset of slim models that supports adding back IDE connectivity.
                                    • PedroGG90
                                      بدر الدين
                                      • Feb 2023
                                      • 30
                                      • Morocco
                                      Yep, am lucky I got this silver 7000x
                                        SHUTTLE XPC slim DX30 XPC slim J3355 Specification for Upgrade or Repair
                                        This specification for the SHUTTLE XPC slim DX30 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DX30 boardview and XPC slim DX30 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE...
                                        09-12-2024, 03:30 PM
                                        SHUTTLE XPC slim DH110 XPC slim i5-7400 Specification for Upgrade or Repair
                                        This specification for the SHUTTLE XPC slim DH110 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DH110 boardview and XPC slim DH110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                        09-12-2024, 03:28 PM
                                        HP Slim Desktop S01-aF0011ns Slim Desktop J4005 Specification for Upgrade or Repair
                                        This specification for the HP Slim Desktop S01-aF0011ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0011ns boardview and Slim Desktop S01-aF0011ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        HP Slim Desktop S01-aF0010ns Slim Desktop J4005 Specification for Upgrade or Repair
                                        This specification for the HP Slim Desktop S01-aF0010ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0010ns boardview and Slim Desktop S01-aF0010ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        SHUTTLE XPC slim Office DL1000XA XPC slim J4005 Specification for Upgrade or Repair
                                        This specification for the SHUTTLE XPC slim Office DL1000XA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim Office DL1000XA boardview and XPC slim Office DL1000XA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
