Ayaneo 2021 pro short help
  • kew1701
    • Nov 2013
    • 40
    • Poland
    Hi,device had removed usbc pd driver chip cypd5225 because it was hot,when i got mainboard i connected it to usb charger to test,and after 2-3 tries HP8K24 chip got fried.main voltage was ok(it is ryzen 7 4800u console with 11v battery).Im not very familiar with this design,but after long time i found short on rt3663bm chip on OFSAA( pin24 & 23(resistance to ground0.4ohm),which is doing overclocking through NB of CPU.I have pulled all coils,but
    lowest resistance to ground is 3ohm on cpu side...Is cpu dead?
  • kew1701
    • Nov 2013
    • 40
    • Poland
    Re: Ayaneo 2021 pro short help
    In the meantime i removed rt3663bm chip,"short" is still there on traces that lead to this chip pin24&23...In manual says :23 Over clocking offset setting for the VDD controller.
    24 OFSA Over clocking offset setting for the VDDNB controller.
      • 22182
      Post some pictures please
      • kew1701
        • Nov 2013
        • 40
        • Poland
        Here are pics with coils lifted
        • AndyBNoobTech
          • Sep 2022
          • 12
          • United Kingdom
          Has anyone got any further with this? I've got one that won't charge at all and the CYPD5225 IC is the only thing that gets warm. One cap at the bottom right reads 8.5ohm at the top nearest the IC, and 0.2 ohm at the bottom (assuming ground). See attached pic
          Any help is greatly appreciated, never worked on one of these before!
          Andy
          • mon2
            • Dec 2019
            • 14753
            Post the full topside markings of this power delivery controller. Is it a bga or qfn package?
            • kew1701
              • Nov 2013
              • 40
              • Poland
              Andy
              Mine is 9.2ohm top,0 bottom
              • kew1701
                • Nov 2013
                • 40
                • Poland
                It is bga chip...
                • AndyBNoobTech
                  • Sep 2022
                  • 12
                  • United Kingdom
                  I also found the audio IC had gone pop.... seems to have arc'd to the bottom of the wifi board. I also get a lot of heat from a small IC marked DDN149, on the opposite side of the board to the CYPD5225 IC, but i can't find any info. No shorts found around the IC. It has 3.3v one side and 8v the other, not sure if it's up or down converting.
                  Pics for reference
                  Thanks for the quick replies!
                  • AndyBNoobTech
                    • Sep 2022
                    • 12
                    • United Kingdom
                    So that appears normal then. Is that with the IC removed?
                    I haven't taken mine off yet as I don't want to have to reball it if it isn't the issue!
                    • kew1701
                      • Nov 2013
                      • 40
                      • Poland
                      No,i soldered another IC then measured,i don't know where to start with this������
                      • AndyBNoobTech
                        • Sep 2022
                        • 12
                        • United Kingdom
                        I'm also getting a 4ohm reading to ground on both sides of the caps and coils next to the CPU.... it's not looking good...
                        • kew1701
                          • Nov 2013
                          • 40
                          • Poland
                          The cpu has southbridge which is connected to pd controller directly,probably when chip died,it has taken cpu with it...it is such design...that is me thinking loud...
                          • cientifiqus
                            Devops
                            • Oct 2024
                            • 3
                            • Colombia
                            Hello
                            I have an ayaneo NEXT with the same PCB and the same shorts. Mine stops working one day and smoke comes out around the power button. After opening it the usb-c chip was burned.
                            When I try to turn it on, it turns the cpu fan at max speed and no video output. The battery is fully charged.
                            The usb-c port only takes 5v. I'm planning to remove the usb-c chip and try to use the device with battery only to check its health or something.
                            Also, I notice that there is another battery connector that only has + and - contacts so maybe use it to power on the device.
                            The thing is that I came across this post and after checking the image I have short to ground one mosfet and all coils around the battery side of APU. I will try to find what causes the short.
                            I didn't find any schematics at all. I found some for different chips like controllers for charging and power on the device with brand "ITE".
                            The post was like a year ago, please let me know any progress you have made since then.
                            By the way, the device died after an electric storm and the device was connected to my usb hub deck. The hub is ok.
                            I tested a lot of condensers and they have continuity but I have no idea if they are supposed to be like that. maybe I could remove one by one and check continuity desolders to check if they are ok at least.
                            I'm using the 1tb m.2 drive on my main computer so it's ok too.
                            • cientifiqus
                              Devops
                              • Oct 2024
                              • 3
                              • Colombia
                              Hello
                              I removed the usb-c chip and now the vrm controller chip is in short circuit...
                              I will ask someone with knowledge on boards repair.
                              • ssssteve
                                • Dec 2015
                                • US
                                Hi. I'm wondering if anybody has successfully managed to repair this. Is there any confirmation that the APU gets fried in these situations?
                                I have an Ayaneo Next with the same exact problem. It powers on to the fan spinning, no boot and only that cypd5225 BGA USB chip gets extremely hot.
                                I don't see any physical damage to other chips. Here's a picture. I bought it used and the previous owner semed to really enjoy thermal compound!
                                Thanks for any advice.
                                • DynaxSC
                                  Extreme High Current & Low Voltage Short Killer ??
                                  by DynaxSC
                                  Hi Folks
                                  I'm looking for a extreme high current short killer solution for a reasonable cost.
                                  I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                  After taking off the socket, the shorts dissappear again.
                                  The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                  10-15-2024, 10:13 AM
                                  LG GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY Ultrabook Specification for Upgrade or Repair
                                  This specification for the LG GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY boardview and GRAM 16 2021 (16Z90P-G.AA65Y) - CZARNY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                  09-07-2024, 04:10 AM
                                  LG GRAM 16 2021 (16Z90P-G.AA66Y) - SREBRNY Ultrabook Specification for Upgrade or Repair
                                  This specification for the LG GRAM 16 2021 (16Z90P-G.AA66Y) - SREBRNY Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GRAM 16 2021 (16Z90P-G.AA66Y) - SREBRNY boardview and GRAM 16 2021 (16Z90P-G.AA66Y) - SREBRNY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                  Huawei MateBook MateBook X Pro 2021 Notebook X Pro Specification for Upgrade or Repair
                                  This specification for the Huawei MateBook MateBook X Pro 2021 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MateBook X Pro 2021 boardview and MateBook X Pro 2021 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  09-07-2024, 03:40 AM
                                  Huawei MateBook 2021 Notebook D 15 Specification for Upgrade or Repair
                                  This specification for the Huawei MateBook 2021 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 2021 boardview and 2021 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Huawei MateBook...
                                  09-07-2024, 01:00 AM
