Re: Aoyue 738 4 in 1 solder station power board
Hi mate
Not quite sure where the 5v circuit starts and ends
was going to see if the front panel gets any power by testing the plug cant realy test on the board in situe
Where would the best ground point to test from Com
Thanks for all your time
It's long at 26-28mm and almost 8mm dia., out of china that would be a 5W mox. for the size.
Another way to look at it, assuming it's in series with the heater for some silly weird reason, 600W heater 2.5A 240VAC gives 7.5W on a 1.2Ω resistor in series. But it's (heating element) not on all the time, so maybe it works in the bowels of guangdong.Leave a comment:
Ok
I have a new problem the board is powered but no display and no heat
But its on and trying
can anyone help further
ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
it's not 5-7w because it's gray non-inductive fuseable.
more like 3wLeave a comment:
Hi mate
It's 22x8 1.2ohm 5-7w
some of the ones i looked at were 50mm
cheers mateLeave a comment:
Hi all
polished up the resistor it is infact 1.2Ω on the calculator
brown red gold gold
What would my alternatives be
cheersLeave a comment:
Ok
The resistor gives no measurements
The ba12 -600b in resistence mode pin 1 to 2 o.l
pin 1 to 3 .028 beep
ohms 1 to 2 o.l pin 1 to 3 43.9ohms
As to the resistor being there i think it shows great forsite to know that some idiot is gonna pull out a heating element while plugged in
as for the 1.2 it was suggested earlier
it could mean 1.2 jigawatts
so not sure but quite hard to get the right size and wattage
Cheers for your helpLeave a comment:
Test the BTA12-600B triac in-circuit is OK (with connectors off), check for a short across A1 and A2 pins. That is the most common way they fail.
The resistor what does it read with ohmmeter? You think it's 1.2Ω matching the PC board silkscreen? I still wonder what it's for lol.
Any 5-7W wirewound resistor will do. Keep the high-temp insulating sleeves.
It's what fits. Yageo KNP500 series or SQP500. Royal Ohm PRW05, KNP05 seems too small.
I don't know what distributors you have over the pond.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi
Thanks so much for all the help
redwire what do you think i should replace the resistor with?
And do i need to remove from the circuit to test
it is a ST bta12600b then c3 over left leg and 06 over right
I cut the resistor then read the triac and across outside pins it shows dead short
cant seem to get the screw out of it thou
Thanks againLeave a comment:
That resistor (size 26x8mm?) is looking like 5W Metal Oxide, a chinese special - uncommon because you would find wirewound, ceramic at that power or higher. It might even be 6-7W, basically the largest they could stuff in there.
If it's got 3A flowing through it, that's still almost 11W so I'm not sure why they even have it in series with the heater. Seems odd.
Possibly connects to the triac near it, in the corner. I would check if it shorted which would cause the new heater to be full on and cause a meltdown.
Check ohms/diode-test MT1 and MT2 pins.Leave a comment:
here's a couple of schematics from similar devices to give you a starting reference.
as you can see, i like to archive tool schematics!
good - that simplifies it greatly.
the hot air is mains powered through a triac - see if you can find a triac on a heatsink.
part number is probably starting with "BT"
i would expect it to be close to the mains and output connectors.Last edited by stj; 07-28-2023, 06:58 AM.Leave a comment:
Hot air
which element was it, the iron or the air?Leave a comment:
Hi mateAll I can see is the big power resistor (PC board silk says 1.2Ω) looks cracked and blown out. It must have acted as the fuse, although what happened to the unit's main fuse? assuming it has one. It must have been a scary experience.
This would coincide with shorting out the heater when power was on.
Check the resistor is not open-circuit.
I think the high-tech in this product must be secured for the People by sanding off the IC markings
cross-posted at https://www.eevblog.com/forum/repair...n-power-board/
do you know what wattage that ressistor will be to add to my shopping list
And yes was very scary
shat myself
the bang seemed to happen in my hands and the smoke came from the unit utter confusion
hahaLeave a comment:
start by explaining which connectors are for the element and the power input.
did somebody take a grinder to the chip numbers or is that paint?[/QUOTE]
Hi mate thanks for the reply yes somebody took a grinder to the ic's on the power board but not on the other board.Dont know why?
The main fuse is untouched.
I did post on another forum i am a member of.
just hoping somebody can tell me what to measure and what that means and hoping it hasn't touched the other board.
thanks for your help so far guys.Attached Filesif you find these attachements useful please consider making a small donation to the site
cross-posted at https://www.eevblog.com/forum/repair...n-power-board/Leave a comment:
did somebody take a grinder to the chip numbers or is that paint?Leave a comment:
Assuming...7 Photos -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by defdjamelHi everyone,
I’m trying to remove a component from a 2021 MacBook logic board, but I’m having trouble.
https://www.electronicsdatasheets.co...s/tlv70733pdqn
I’m using hot air at 480 °C with full airflow and good flux, but the solder paste is not melting.
I know there’s a lot of thermal dissipation from the board, and I suspect the copper planes are absorbing most of the heat.
Do you have any tips for this kind of board? Would a preheater help?
Thanks in advance!
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... - Loading...
