Dell optiplex 3000 micro bios
  • Arrow16
    • Apr 2022
    • 229
    • Philippines
    #41
    Re: Dell Optiplex 3000 Micro Bios needed
    Problem: Absolute enable/ need to disable
    Board i12 ADL 6L
    202040-1
    D10NK$CA
    rev: A00
    service tag: 532MXR3
    Flash this to 32mb chips , put back 16mb chip, giv feddback enjoy!!!
    • superdota2
      • Jun 2015
      • 64
      • PHILPPINES
      #42
      thank you, it works
      • tonnyz
        • Oct 2021
        • 14
        Re: Dell optiplex 3000 micro bios
        Please help, please remove password and disable absolute. Thanks.
        Service tag: BQ7WFT3
        • tonnyz
          • Oct 2021
          • 14
          please help me, thank you.
          • volinakis
            • Jan 2021
            • 2874
            • N/A
            #45
            put back 32Mb as is and write only 16Mb
            • tonnyz
              • Oct 2021
              • 14
              Thank you.
              Password has been removed, but absoluted has not. No problem, with Dell's bios, absoluted can be turned off if you use windows for 3 days.
              • bobans1983
                • Jun 2015
                • 10
                • sdtb ghn
                #47
                any solution for dell optiplex 3000 micro pc
                two bioses
                gigadevice 25b128esig
                gigadevice 25R256eyig
                wich to reprogram
                locked bios ..
                thanks in advance
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12354
                  #48
                  two bioses
                  wich to reprogram
                  locked bios ..
                  thanks in advance
                  Both
                  • bobans1983
                    • Jun 2015
                    • 10
                    • sdtb ghn
                    #49
                    Where to download unlocked bios. Or can i unlock mine
                      • 22001
                      You can unlock yours.
                      https://www.badcaps.net/forum/showthread.php?t=103569
                      • Coop3167
                        • Dec 2023
                        • US
                        #51
                        I have the same problem with my Dell... Can anyone help me with the password or bios update
                      • toshyou
                        • Jan 2023
                        • 35
                        • singapore
                        #52
                        Can someone make me new bios bin for dell 3000 mini pc
                        SN: GSZ W7T3
                        Unit is blinking 3 amber and 6 white it could be bios corrupted
                        NOw is ok, il change 32MB file...
                        • fergz
                          • Jul 2015
                          • 5
                          • Philippines
                          #53
                          Hi. pls help me remove admin password
                          service tag: 42127V3
                          thank you
                          • adamgouadma
                            • Jul 2017
                            • 202
                            • setif
                            #54
                            RA Dell optiplex 3000 Please remove the password Service tag is G0GKBT3
                            • Amplot
                              • Jan 2024
                              • Philippines
                              #55
                              Thank you for checking I have read the bios files again. This time I believe its
                              correct, please see the attachment.
                              FYI if anyone is struggling to read MX77L25650F
                              I used CH341A
                              I had to add the chip to the database of the CH341A Programmer V1.03 by adding the line in the chiplist file.
                              <MX77L25650F id="C27519" page="256" size="33554432"/>
                              Hope this info is useful for anyone with the same chip.
                              Hi what connector did you use? sop16 to dip8?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12354
                                #56
                                Unlocked
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12354
                                  #57
                                  SN: GSZ W7T3
                                  aaa
                                  • adamgouadma
                                    • Jul 2017
                                    • 202
                                    • setif
                                    #58
                                    Originally posted by hoaca388
                                    Unlocked
                                    Thank you very much
                                    • johnllagas
                                      • Dec 2017
                                      • 4
                                      • Philippines
                                      #59
                                      Can someone help me remove the password and absolute computrance of this bios. Thank you.
                                      ST: GKLFXW3
                                      • bpopilek
                                        • May 2013
                                        • 9
                                        I just picked up a Optiplex 3000 Micro and it has the Absolute feature enabled. I want to permanently disable this option. I plan to dump both BIOS chips today, and I can post the files to have someone do the work for me. However, I would also like to learn how to make the changes myself. Are there any resources or tutorials specific to Optiplex Micro or Dell BIOSes that someone can point me towards? Also, I just wanted to confirm that I need to dump the 25B128ESIG (16mb) and 25R256EYIG (32mb) chips. Thanks!
                                      • Altemon Moura
                                        Optiplex 3000 micro
                                        by Altemon Moura
                                        Unfortunately, when removing the chip
                                        (GIGADEVICE 25R256EYIG)
                                        It broke in the hot air.
                                        Will I be able to buy this same model?
                                        (GD25R256EYIG)
                                        "Can I burn the Bios?"
                                        motherboard
                                        DELL Optplex 3000 - 202040-1 D10NK$HA
                                        Optiplex 3000 micro
                                        Service tag: C7CG7T3
                                        SERVICE CODE: 26565563271​
                                        05-20-2025, 06:35 AM
                                        DELL OptiPlex 3070 OptiPlex 3000 i5-9500T Specification for Upgrade or Repair
                                        This specification for the DELL OptiPlex 3070 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3070 boardview and OptiPlex 3070 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                        09-12-2024, 03:44 PM
                                        DELL OptiPlex 3060 OptiPlex 3000 i5-8500 Specification for Upgrade or Repair
                                        This specification for the DELL OptiPlex 3060 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3060 boardview and OptiPlex 3060 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                        DELL OptiPlex 3050 OptiPlex 3000 i5-7500 Specification for Upgrade or Repair
                                        This specification for the DELL OptiPlex 3050 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3050 boardview and OptiPlex 3050 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                        DELL OptiPlex 3070 OptiPlex 3000 i5-9500 Specification for Upgrade or Repair
