HP EliteDesk 805 G6 Mini PC
  • skypc86
    • Dec 2021
    • 5
    Hello, can someone please remove the bios password?
  • hardware1
    • Sep 2021
    • 2936
    • N/A
    Re: HP EliteDesk 805 G6 Mini PC
    Try the first file only, if the password still there use the both files.
    In the first boot remember to go into bios menu to disable all security options.
    all donations are welcome,
    • skypc86
      • Dec 2021
      • 5
      Thank you very much, I'll test that right away.
      • skypc86
        • Dec 2021
        • 5
        I finally managed to test it today and it worked straight away! THANK YOU SO MUCH!
        • Raulddan
          • Dec 2022
          • 4
          • Romania
          Does this work for any 805 G6 Mini PC ?
          I bought one second hand and the owner swears that he didnt set-up any bios password and he had the pc from new. He even sent me the invoice which is on his name.
          The issue is that only when I try to enter Bios Setup it asks for password.
          The other owner bought it with Windows allready on it and when he sold it to me he formated the disk and now when I try to boot from an install stick it give a security error and Im stuck, its just useless without the bios administrator password
          Can you guys help me out ?
          • hardware1
            • Sep 2021
            • 2936
            • N/A
            Upload the content of your 2 firmware chips and someone will help you.
            • Raulddan
              • Dec 2022
              • 4
              • Romania
              Can you please guide me on how to do it ? I mean how to dump the bios from the PC. I sweat my brain for couple of hours and I cant managed to do it
              • volinakis
                • Jan 2021
                • 2738
                • N/A
                https://www.badcaps.net/forum/showth...t=phoenix+bios
                • Raulddan
                  • Dec 2022
                  • 4
                  • Romania
                  Oh, I guess its out of my hands I may be better in finding a local shop for this delicate process.
                  Thank you very much, best regards
                  • pedrossy
                    • Jun 2023
                    • 5
                    • FRANCE
                    I am a new member, computer enthusiast, and very happy to discover your forum which is a gold mine
                    I bought a second-hand HP EliteDesk 805 G6 small PC, and I noticed afterwards... that the bios is protected by a admin password.
                    I have access to W10 as an admin, but features and devices (networks) must be disabled in the bios protected by this password.
                    I read rules and your instructions, and I understand that thanks to the "HP firmware update and recovery" utility under W10 (downloaded from the official HP driver / last bios release), I created a restore (actual) flash bin, attached : 2 files (that look identical / size) automatically created when I opened the HP application.
                    I also attached the last official HP bios release version S09_02120100.bin, I don't know If you need it...
                    Could you help me to remove the password from these .bin file.
                    I understand that the next steep, always with this HP utility under W10, is to update the firmware with you .bin modified, isn't it ? by renaming your new .bin file with the name of the .bin file provided in the HP application (S09_02120100.bin)
                    Could you confirm that during this process, HP application will not ask me the current bios password ? And all these manipulations don't require to physical extract the EEPROM from the motherboard, and read/write it with an external programmer...
                    Thanks a lot for your help !
                    Pierre
                    • pedrossy
                      • Jun 2023
                      • 5
                      • FRANCE
                      Is there something in particular that I missed for people to help us / answer us on this forum when we are new?
                        • 21017
                        You will need to use an SPI bios programmer.No other way.If the chip type is SOP8 you could use a sop8 clip to avoid desoldering,or if the chip type is WSON8 you could use a WSON8 pogo adapter, but using both types are not very reliable,its much better to desolder the chip and attach it to an adapter that then goes into the programmers zif socket.
                        Once youve made a backup post it here,removing the password isn`t a problem.
                        https://www.badcaps.net/forum/showpo...49&postcount=2
                        • pedrossy
                          • Jun 2023
                          • 5
                          • FRANCE
                          Hello SMDFlea
                          Thank you for your answer.
                          I checked, it is a MX25L25673G EEPROM => SOP8, so I will buy a programmer from ali.
                          When you say SOP8 adapter "often lead to an empty or corrupt dump"
                          => this is due to the clip moving (bad pin connections) or electrical interferences (3V/5V) ?
                          By the way, with the SOP8 adapter, during the manipulation (read/write), the PC (of the EEPROM) remain power off ? and the EEPROM is power by the USB of the PC which read the data ?
                          If you have a youtube link to explain the manipulation, and avoid errors...
                          • kulokutoys
                            • Jun 2010
                            • 132
                            • Phillippines
                            is there any jumper labeled something PSWD under the fan. if it has, remove the jumper then boot the unit then go to bios check if its cleared. then shut down the unit put back the jumper then power on. I had those few mini pc intel and amd based and has jumper, not sure on yours.
                            • pedrossy
                              • Jun 2023
                              • 5
                              • FRANCE
                              Hello kulokutoys, thank you for your help.
                              unfortunately no... no jump on this late motherboard. I don't have a hot gun (and soldering would void the warranty still in progress), I'm going to use a SOP8 adapter clip after disassembled the PCB of the MB (not powered), do you know what is the risk of this not reliable method ? to damage the EEPROM or having to repeat the operation several times ? "often lead to an empty or corrupt dump" Thank you
                              • kulokutoys
                                • Jun 2010
                                • 132
                                • Phillippines
                                for me I dont use clips, it always gives a bad reading on the chip. maybe try pogo pins for sop8 with a good programmer. Im not well sure if your chip is running at 3.3v probably if am4 it should be 1.8v if I am correct. make sure you google first the chip then prepare a certain adaptor for it. dont you use direct 3.3v programmer , some pins on EEPROM are connected also in the SIO.
                                • cberlinette87
                                  • Jun 2023
                                  • 0
                                  Re: HP EliteDesk 805 G6 PC
                                  Hello, Can you help unlock the Bios password? HP EliteDesk 805 G6 dump files attached.
                                  • kulokutoys
                                    • Jun 2010
                                    • 132
                                    • Phillippines
                                    there is something wrong on your read file. I'm not sure can you reread it again?
                                    • r.torres
                                      • Jul 2023
                                      HP EliteDesk 805 G6 mini
                                      Hello all,
                                      I got a really sweet deal on the PC from the thrift store but when I took it home and powered it on, it asks for a BIOS Administrator password.
                                      Can someone please help me either find what the password is or remove it completely?
                                      I dumped both MX25L25673G chips on the board, hopefully it was done correctly. Both included in same zip file.
                                      Thank you for the help!
                                      • ctvedt
                                        • 3
                                        • Norge
                                        Hi, would really appreciate help removing BIOS password on my 805 G6 mini pc. Unable to use tools like RCUnlocker as this does not support this 32MB chip. HPUnlocker does not list EliteDesk or G6 as supported models, so I'm reluctant to use this tool.
                                        I have attached verified reads from both chips (marked BIOS and PRVROM)
                                        Model: HP EliteDesk 805 G6 Desktop Mini PC
                                        Serial No: 8CC1281J87
                                        Product No: 2Q296AV
                                        Chip: MX25L25673G​
