HP EliteDesk 805 G6 Mini PC
  • ctvedt
    • Norge
    Managed to fix it myself using an hex editor, writing FF from 0x00037000 to 0x00037700. Address range found for G6 searching this forum. PC works fine now!
    • rex98
      • Feb 2023
      • 1287
      • Mandaue CEBU, Philippines
      okay
      • buglerbalint
        • Aug 2021
        • 17
        • Austria
        In which chip is the password stored? In BIOS or in PRVROM?
        • ctvedt
          • Norge
          PRVROM
          • Hell_Blaza
            • Oct 2024
            • AUSTRALIA
            Hi Guys what hex editor do you use?
            Will any fixed bios files uploaded here work for any 800 G6?
              • 21597
              HxD and a few others.
              No. This thread is for the 805 G6
              • kaisies
                • Oct 2024
                Great forum - stumbled upon this trying to remove BIOS password from a few EliteDesk 805 G6's I've got. Was able to get a dump of the bios, I THINK. Chip says - MX25L3255E. asprogrammer / neoprogrammer doesn't have that one listed. Was able to pull presumably the BIOS using MX25L3275E - the hex shows a fair bit of non-gibberish strings so I think its good. However the RCUnlocker shows Missing Unlockable content when I drop the BIN in. Any help appreciated!
                HP EliteDesk 805 G6 SN: MXL1143X8F MB: DA0F92MB6F0 Rev F
                  SMDFlea commented
                  Editing a comment
                  post moved to 805 G6 thread topic.
              • kaisies
                • Oct 2024
                Well per this link: https://smh-tech.com/macronix-mx25l3255e/ I wonder if im not grabbing the BIOS, since its only a 4MB chip. The other chips on the board don't seem to be marked that they are bios chips though. Could someone let me know where the BIOS (and I guess the PRVROM) are located on the mobo? It seems I need both...
                • bbanana
                  Father Land
                  • Oct 2021
                  • 164
                  • Vietnam
                  #29
                  Hi, would really appreciate help removing BIOS password on my 805 G6 mini pc. Unable to use tools like RCUnlocker as this does not support this 32MB chip. HPUnlocker does not list EliteDesk or G6 as supported models, so I'm reluctant to use this tool.
                  I have attached verified reads from both chips (marked BIOS and PRVROM)
                  Model: HP EliteDesk 805 G6 Desktop Mini PC
                  Serial No: 8CC1281J87
                  Product No: 2Q296AV
                  Chip: MX25L25673G​
                  Flash this file. first boot go to bios setup- security tab and apply security to default.
                  • kaisies
                    • Oct 2024
                    Well, after I found the right BIOS & PVROM chip - hint, its not the SOP8, its the 2 WSON8 chips under the HDD sled / next to the PCI wifi slot - I was able to desolder, dump, and fix! My first time using a heat gun, and on as small of a chip to boot.
                    Thanks for this - was super easy to do and instantly worked. My PVROM had data up to 37AA0, I Cleared it for good measure and it worked just fine. There's more data @ 38000 that starts with NvramActiveRegn, I DID NOT clear this and it still let me into BIOS with no PW just fine.
                    I did *JUST* the PVROM chip - NOT the BIOS chip, as a few others have mentioned.
                    • Michael.87
                      • Nov 2024
                      • Poland
                      #31
                      Hi i have similiar problem , i have hp dm 805 g6 mini but my chips are different , both of chips are gigadevice 25b256dyig 32MB and dumped it with gd25LQ256C_1.8v with ASProgrammer and ch341a programmer, can someone check if this is ok to play with removing bios password ?
                      Serial No: 8CC2383930
                      Product No: 2Q294AV
                      Chip: GD25B256DYIG
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12240
                        #32
                        Product No: 2Q294AV
                        Chip: GD25B256DYIG
                        File prvrom.zip was corrupted.
                        Serial_8CC2383930
                        BuildId_20WWQ7FT601#SABH#DABH
                        Feature byte_3E476J6S6b7B7H7M7Q7T7W7maBapaqaubhcAdpdqfPhKhZjhk8mEnWpq.DG
                        Product_2Q294AV
                        • ctslive
                          ctslive
                          • Apr 2025
                          • US
                          #33
                          i have an HP EliteDesk 805 G6 Mini with a locked BIOS.
                          Do I use the HP BIOS Configuration Utility to create the files?
                          If yes, please provide commands.
                          Thanks!
                          • nsixtyfour
                            • Mar 2015
                            What tool can I use to verify my prvrom dump is not corrupted before I overwrite 0x00037000 to 0x00037700 with 0xFF and write it back?
                            • Darkfutur
                              • Jul 2025
                              • Ireland
                              #35
                              Hi guys. I bought an EliteDesk 805 G6 with a locked password. Can you help me locate the BIOS chip—do you know which one it is? I’ve marked the suspected one with a red circle. Also, will a CH341A programmer with a clip be enough for this operation? Thanks!
                              • ayman elsherif
                                • Dec 2021
                                • 10
                                • egypt
                                #36
                                Hi, can someone please remove the bios password?
                                HP EliteDesk 805 G6 Small Form Factor PC RCTO Base
                                  • 21597
                                  Post the PC serial number - https://www.badcaps.net/forum/troubl...before-posting
                                  • ayman elsherif
                                    • Dec 2021
                                    • 10
                                    • egypt
                                    #38
                                    Originally posted by SMDFlea
                                    SN/MXL1314NK7
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12240
                                      #39
                                      SN/MXL1314NK7
                                      Unlocked
                                      • pedrossy
                                        • Jun 2023
                                        • 9
                                        • FRANCE
                                        #40
                                        Hello
                                        I have a bootloop issue on my HP 805 G6 SFF. After a Windows 11 SP, the BIOS was updated... to a v2023 known by HP to generate bootloops, a sign of planned obsolescence !
                                        I can still access the BIOS, but since I don't have the password, I need your help.
                                        I have a CH341b black PCB (+3.3V mod with your tuto) + SOP8 adapter clip, but I still get the "IC not responding" error in NeoProgrammer.
                                        The motherboard is disassembled, the CMOS battery is removed. I've tried several USB connectors to connect the CH341 and I've repositioned the clip adapter several times, but always "IC not responding."
                                        The PC boots with the BIOS, so the EEPROM is working.
                                        I have 3 questions :
                                        - Do you have any explanations / suggestions ? Is there anything I did wrong? before investing in a more expensive solution like the Xgecu T48.
                                        - I read lot of comments and why do you need two dumps? "Download the contents of your two firmware chips" are you talking about the same chip? one dump is not enough?
                                        - I know that using my hotgun to desolder is more reliable than clip adapter, but I'm a little afraid of burning chip or break a pin...
                                        If I buy a new blank MX25L25673GZ4I-08G chip (3$), is it possible to program it without needing to read the original(dump backup), flashing with an adapted .bin (combinaison of official HP .bin file with Serial & Product No) ?
                                        Thanks for your help
