HP EliteDesk 805 G6 Mini PC
  • pedrossy
    • Jun 2023
    • 9
    • FRANCE
    #41
    Originally posted by Darkfutur
    Hi guys. I bought an EliteDesk 805 G6 with a locked password. Can you help me locate the BIOS chip—do you know which one it is? I’ve marked the suspected one with a red circle. Also, will a CH341A programmer with a clip be enough for this operation? Thanks!
    Hello Darkfutur, apparently you haven't received any answer and I don't know if your request is still relevant after several months.
    I haven't seen much feedback / sharing experience on this forum, which is a shame, because I know it's not easy when you're just starting out, and mutual assistance is important.
    I've been reading the forum tutorials for a few days, and you also need a basic understanding of electronics.
    To answer your question, the BIOS is the lowest chip you circled in red. Zooming in, you can see Macronix MX25L25673GZ4I-08G, which operates at 3.3V. There's no other solution than reflashing this chip to clear the password...
    The operation will consist of extracting the data from this chip (dump) to create a backup, posting it here (.bin) with your serial n° and product n°, then rewriting the chip with the unlocked version that the forum experts will generate.
    As mentioned in the tutorials, the CH341A programmer + clip solution is economical but the least reliable... first of all, if you have a black CH341A version, it won't work natively, because it's not at the right voltage (5V), you'll have to adapt it...
    Personally, it didn't work... and I don't know if it's related to the mod or the clip... in short, I'm going to buy an XGecu T48 that you can find for €50 on AliExpress.
    Secondly, the clip is not recommended, because even when properly positioned, the presence of other nearby components can cause interference/errors. It is recommended to desolder with an hot gun (270°C <1 min).
    If you're already trying with the clip, you'll need to remove the motherboard, stripping it of all peripherals, power supply, CMOS battery to limit interference, etc., and be sure not to make a mistake when positioning the clip from pin 1 (red wire) to the pin of the small dot on the chip side; this is important to avoid burning the chip.
    I recommend reading the forum tutorials, which are well done, plus YouTube!
    Pierre
    • pedrossy
      • Jun 2023
      • 9
      • FRANCE
      #42
      I need your help to remove BIOS password, attached .bin dumped of the 2 chips (BIOS and PRVROM).
      Thank you very much
      Model: HP EliteDesk 805 G6 Desktop SFF (Small Form Factor PC) => not the mini but the small desktop VERSION
      Serial No: CZC135BPBW
      Product No: 273D7EA#ABF
      BIOS version : S09 02.12.01 03/27/2023
      2 Chips MX25L25673GZ4I-08G (WSON8 3.3v) :
      - BIOS near CPU
      - PRVROM near PCIe and RAM => I understand that this chip countains the BIOS password and it have be reflashed with the .bin version you will unlocked
      • hoaca388
        Badcaps
        • Jan 2022
        • 12240
        #43
        Thank you very much
        - BIOS near CPU
        Unlocked
        • pedrossy
          • Jun 2023
          • 9
          • FRANCE
          #44
          Thank you very much hoaca388, you are a master.
          I have success to clear password, but in my case, flash a new bios has no fix my bootloop issue... Mothermoard is defective after Windows 11 cumulative updated, I will never buy HP again, especially since I am not the only one affected.
