Hello, can someone please remove the bios password?
HP EliteDesk 805 G6 Mini PC
Re: HP EliteDesk 805 G6 Mini PC
Try the first file only, if the password still there use the both files.
In the first boot remember to go into bios menu to disable all security options.Attached FilesPremium supporters get full download access and other benefits.
Does this work for any 805 G6 Mini PC ?
I bought one second hand and the owner swears that he didnt set-up any bios password and he had the pc from new. He even sent me the invoice which is on his name.
The issue is that only when I try to enter Bios Setup it asks for password.
The other owner bought it with Windows allready on it and when he sold it to me he formated the disk and now when I try to boot from an install stick it give a security error and Im stuck, its just useless without the bios administrator password
Can you guys help me out ?
ThanksComment
Upload the content of your 2 firmware chips and someone will help you.Does this work for any 805 G6 Mini PC ?
ThanksComment
please support this forum
-----------------------------------------------------Comment
Oh, I guess its out of my hands
I may be better in finding a local shop for this delicate process.
Thank you very much, best regardsComment
I am a new member, computer enthusiast, and very happy to discover your forum which is a gold mine
I bought a second-hand HP EliteDesk 805 G6 small PC, and I noticed afterwards... that the bios is protected by a admin password.
I have access to W10 as an admin, but features and devices (networks) must be disabled in the bios protected by this password.
I read rules and your instructions, and I understand that thanks to the "HP firmware update and recovery" utility under W10 (downloaded from the official HP driver / last bios release), I created a restore (actual) flash bin, attached : 2 files (that look identical / size) automatically created when I opened the HP application.
I also attached the last official HP bios release version S09_02120100.bin, I don't know If you need it...
Could you help me to remove the password from these .bin file.
I understand that the next steep, always with this HP utility under W10, is to update the firmware with you .bin modified, isn't it ? by renaming your new .bin file with the name of the .bin file provided in the HP application (S09_02120100.bin)
Could you confirm that during this process, HP application will not ask me the current bios password ? And all these manipulations don't require to physical extract the EEPROM from the motherboard, and read/write it with an external programmer...
Thanks a lot for your help !
PierreAttached FilesPremium supporters get full download access and other benefits.
You will need to use an SPI bios programmer.No other way.If the chip type is SOP8 you could use a sop8 clip to avoid desoldering,or if the chip type is WSON8 you could use a WSON8 pogo adapter, but using both types are not very reliable,its much better to desolder the chip and attach it to an adapter that then goes into the programmers zif socket.
Once youve made a backup post it here,removing the password isn`t a problem.
https://www.badcaps.net/forum/showpo...49&postcount=2
.Last edited by SMDFlea; 06-20-2023, 05:00 AM.Comment
Hello SMDFlea
Thank you for your answer.
I checked, it is a MX25L25673G EEPROM => SOP8, so I will buy a programmer from ali.
When you say SOP8 adapter "often lead to an empty or corrupt dump"
=> this is due to the clip moving (bad pin connections) or electrical interferences (3V/5V) ?
By the way, with the SOP8 adapter, during the manipulation (read/write), the PC (of the EEPROM) remain power off ? and the EEPROM is power by the USB of the PC which read the data ?
If you have a youtube link to explain the manipulation, and avoid errors...
ThanksComment
is there any jumper labeled something PSWD under the fan. if it has, remove the jumper then boot the unit then go to bios check if its cleared. then shut down the unit put back the jumper then power on. I had those few mini pc intel and amd based and has jumper, not sure on yours.Comment
Hello kulokutoys, thank you for your help.
unfortunately no... no jump on this late motherboard. I don't have a hot gun (and soldering would void the warranty still in progress), I'm going to use a SOP8 adapter clip after disassembled the PCB of the MB (not powered), do you know what is the risk of this not reliable method ? to damage the EEPROM or having to repeat the operation several times ? "often lead to an empty or corrupt dump" Thank youComment
for me I dont use clips, it always gives a bad reading on the chip. maybe try pogo pins for sop8 with a good programmer. Im not well sure if your chip is running at 3.3v probably if am4 it should be 1.8v if I am correct. make sure you google first the chip then prepare a certain adaptor for it. dont you use direct 3.3v programmer , some pins on EEPROM are connected also in the SIO.Last edited by kulokutoys; 06-22-2023, 03:24 AM.Comment
Re: HP EliteDesk 805 G6 PC
Hello, Can you help unlock the Bios password? HP EliteDesk 805 G6 dump files attached.Attached FilesPremium supporters get full download access and other benefits.
HP EliteDesk 805 G6 mini
Hello all,
I got a really sweet deal on the PC from the thrift store but when I took it home and powered it on, it asks for a BIOS Administrator password.
Can someone please help me either find what the password is or remove it completely?
I dumped both MX25L25673G chips on the board, hopefully it was done correctly. Both included in same zip file.
Thank you for the help!Attached FilesPremium supporters get full download access and other benefits.
Hi, would really appreciate help removing BIOS password on my 805 G6 mini pc. Unable to use tools like RCUnlocker as this does not support this 32MB chip. HPUnlocker does not list EliteDesk or G6 as supported models, so I'm reluctant to use this tool.
I have attached verified reads from both chips (marked BIOS and PRVROM)
Model: HP EliteDesk 805 G6 Desktop Mini PC
Serial No: 8CC1281J87
Product No: 2Q296AV
Chip: MX25L25673G
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
Channel: BIOS Requests ONLY!
by BerunHello All,
I tried to read the the BIOs chip(GD25B127DSIG) on the mainbord of an HP EliteDesk 800 G6 mini, because the BIOs had an Admin Lock and I got the "HP Endpoint Security Problem" Screen at every startup which is not very useful when I want to use the PC as a Compute Unit for my home media system somewhere in the cellar, so it should perform a restart without any interactions.
I only have the CH341APro Programmer available and did the 3V hardware Mod on it before I tried to read the BIOS chip.
I read the Chip on board 8 times (with power... -
by beBossHi,
as noobie to this please excuse my lack of experience.
I am trying to remove a BIOS password from this machine:
HP ProDesk 400 G6 Mini
but so far I still have no success.
I bought CH341 programmer and decided to give it a try.
The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...-
This specification for the HP EliteDesk EliteDesk 800 65W G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk EliteDesk 800 65W G2 Desktop Mini PC boardview and EliteDesk EliteDesk 800 65W G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....09-12-2024, 03:44 PM
This specification for the HP EliteDesk EliteDesk 800 35W G2 Desktop Mini PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk EliteDesk 800 35W G2 Desktop Mini PC (ENERGY STAR) boardview and EliteDesk EliteDesk 800 35W G2 Desktop Mini PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...09-12-2024, 03:44 PM
- Loading...
