hp prodesk 400 g1 sff bios file
  • Nuri
    • Apr 2018
    • 10
    • Ethiopia
    Hi can u help me, i need this hp prodesk 400 g1 sff bios file
    thankyou
  • hardware1
    • Sep 2021
    • 2946
    • N/A
    Re: hp prodesk 400 g1 sff bios file
    thankyou
    Upload your original bios file.
    all donations are welcome,
    • Neural Gear
      • Apr 2021
      • 7
      • Athens
      I would appreciate it if somebody could fix this dump.
      • OKRPKCOMP
        • Dec 2020
        • 439
        • PAKISTAN
        try
        • Neural Gear
          • Apr 2021
          • 7
          • Athens
          Originally posted by OKRPKCOMP
          try
          Unfortunately it didn't work. I assume this is the original binary from the HP softpaq.
          I had already tried it with no luck.
          • OKRPKCOMP
            • Dec 2020
            • 439
            • PAKISTAN
            One try more. above bios was extracted from hp site
            NOw this one is created by yours backup bios
            • Neural Gear
              • Apr 2021
              • 7
              • Athens
              No luck,I reckon this motherboard might be a goner. I tried this dump on a known working motherboard and it POSTs just fine.
              The wierd thing is that the original dump seems to be damaged as well, tried it on the same known working motherboard and no POST.
              Thank you for your time and effort.
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • m1ch43lzm
                by m1ch43lzm
                Hi everyone
                09-06-2025, 05:47 PM
              • Forest79
                by Forest79
                07-23-2023, 07:39 AM
              • maanee11
                Help to get Lenovo BIOS bin file for Thinkpad T560
                by maanee11
                Hello Everyone,
                I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                05-15-2022, 11:59 AM
              • Sebastian Codrean
                BIOS file for ASUS F542UN laptop
                by Sebastian Codrean
                Hello to all of you! I need help with a BIOS file.
                The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                02-20-2025, 10:25 AM
