Asrock x399 Ohantom gaming 6 Bios bin file
  • arisskarp
    • Nov 2021
    • 15
    • greece
    Hello can I please have Bios bin file for this mobo? I have attached the rom.
    Thanks in advance...
    • 21853
    Re: Asrock x399 Ohantom gaming 6 Bios bin file
    https://www.asrock.com/mb/AMD/X399%2...index.asp#BIOS ,just rename the file from *.xx to *.bin
    • arisskarp
      • Nov 2021
      • 15
      • greece
      I've already tried that didn't work
      • hoaca388
        Badcaps
        • Jan 2022
        • 12322
        Obviously the error is not due to BIOS.
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • nolaryie
          BIOS .bin file for ASRock B450M Steel Legend
          by nolaryie
          Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
          I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
          Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
          If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
          Thank you!
          08-06-2025, 12:01 PM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Ovi91
          MSI mpg b550 gaming plus bios bin file
          by Ovi91
          Hi ,I have a motherboard MSI mpg b550 gaming plus and I need a bios bin file to unbrick the motherboard.Is anyone able to help with a bios bin file?
          Thanks 🙏...
          07-18-2024, 04:04 PM
