MSI mpg b550 gaming plus bios bin file
  • Ovi91
    • Sep 2022
    • 16
    Hi ,I have a motherboard MSI mpg b550 gaming plus and I need a bios bin file to unbrick the motherboard.Is anyone able to help with a bios bin file?
    Thanks 🙏
  • Ovi91
    • Sep 2022
    • 16
    I try to flash with usb but not working,the led from motherboard was still flashing after one hour.I want to flash the bios chip with ezp2019 but the file download from MSI is too big ( when I try to write is showing a message that the file is to big)
    • hoaca388
      Badcaps
      • Jan 2022
      • 12392
      Do you keep the original bios ?
      • Ovi91
        • Sep 2022
        • 16
        Yes
        • hoaca388
          Badcaps
          • Jan 2022
          • 12392
          What are you waiting for, post it here.
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • maanee11
            Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
            by maanee11
            Hello Everyone,
            I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
            It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
            In the website, you can only see specs etc.
            I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
            11-08-2025, 04:08 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
          • Forest79
            by Forest79
            07-23-2023, 07:39 AM
