Asrock H81 Pro BTC rev 1.0 Bios - ME Post error
  • 2FA
    • Oct 2022
    • 7
    • Finland
    Greetings,
    I'm in need of a repaired/modified Asrock H81 Pro BTC rev 1.0 Bios, I will attach the bad one as zipped.
    The motherboard is struggling to even POST in its current state, but I've had it to POST a couple times for me to see a "ME FW Downgrade - Request MeSpiLock Failed" error message, and even more rarily a couple of times booting straight to windows with a known good windows drive and being stable for a short while.
    It's been a while since I've worked on this motherboard but if I recall correctly, I have flashed a couple of bios versions from Asrock support site, headers removed for the correct bin size and couple flashes with headers left in being 'wrong sized' bin.
    The attached zip however is the original bios file that got messed up on its own to begin with.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11813
    Re: Asrock H81 Pro BTC rev 1.0 - ME Post error
    Latest version.
    • 2FA
      • Oct 2022
      • 7
      • Finland
      Originally posted by hoaca388
      Latest version.
      Same struggles when trying to POST (short bootloops and then 'no signal' when it finally stays on, and when waiting for a longer period it just shuts back down itself).
      Tested with known good components, with iGPU and with a discrete GPU.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11813
        Nothing more can be done with the bios, here is the virgin file from Asrock.
        • 2FA
          • Oct 2022
          • 7
          • Finland
          I think you're right, I guess some internal components are done for.
          Welp, the board can be used for parts if not for anything else.
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • Vesko356
            by Vesko356
            08-11-2023, 03:27 AM
          • paulwal
            Updating a BIOS on ASROCK
            by paulwal
            Hi. I am not too up on installing BIOS so am looking for a little direction installing a BIOS update.
            https://www.asrock.com/MB/AMD/AB350%...index.asp#BIOS
            I have an ASROCK AB350 Pro4 that is running a P3.00 BIOS.
            CPU is AMD Ryzen5 1500X which I believe is a "Summit Ridge."
            Before I go ahead and update it to the latest version, I thought I would ask whether my plan is right to try and be sure I don't make a mess of things.
            It appears that the latest BIOS for this chip is the 5.80; therefore I need to install (one at a time)…
            10-02-2023, 04:13 PM
          • nolaryie
            BIOS .bin file for ASRock B450M Steel Legend
            by nolaryie
            Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
            I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
            Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
            If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
            Thank you!
            08-06-2025, 12:01 PM
