EVGA 980 kingpin classified
  • Bash0
    • Jun 2021
    • Netherlands
    Im in the search for the schematics of a EVGA GTX 980 CLASSIFIED Kingpin ACX 2.0+ if anyone can help me find them that would be awesome
  • EvilKid500
    • Apr 2021
    Re: EVGA 980 kingpin classified
    Hey Bash, did you ever find them? I'm looking for the same.
    • allietti
      EVGA 3080 Memory replace but i dont know where to find out
      by allietti
      Hi team. i have a EVGA RTX 3080 with 2 IC in short i need to replace but i dont know how to find to buy. the IC only said AL00 1D4H nothing else ii supouse is a memory IC but i dont know. i attach pictures for more information if you can help i really appreciate....
      03-10-2025, 07:57 AM
      by Vesko356
      08-11-2023, 03:27 AM
    • corrize
      Where to find a very small fpc connector 0.3mm between 2 pins ?
      by corrize
      Hello, I search this connector (oxydated).
      It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
      I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
      I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
      Do you know how to find this connector please ? What is the exact name for find it ?
      08-06-2024, 05:25 PM
      Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
      This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
      Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
      07-07-2024, 02:34 PM
    • temyth
      Sentey ATX PSU - ERP650-PS - Trying to find out the right Standby IC
      by temyth
      Greetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
      The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
      01-07-2024, 04:50 PM
