AsusChromebox CN62 (Quanta 0W3 DA0W3MBAB0) BIOS DUMP
  • ogabuga
    • Dec 2013
    • 12
    Hi every one, i need a bios dump for AsusChromebox CN62
    Asus Chromebox for Meeting
    Sticker:
    60M80080-MB
    0060-MB3A01-MB
    CPU i5-5300U
    m2 SSD 16GB
    SPI25q64
  • peste
    • 12792
    • ROMANIA
    Re: AsusChromebox CN62 (Quanta 0W3 DA0W3MBAB0) BIOS DUMP
    Sticker:
    60M80080-MB
    0060-MB3A01-MB
    CPU i5-5300U
    m2 SSD 16GB
    SPI25q64
    post the original bios
    • ogabuga
      • Dec 2013
      • 12
      Hello, this is a dump of my BIOS, i prepared clear ME troth intel fitc tool, but problem is with corporate login. On Asus support page for this Hromebox no BIOS update. I tray to find in BIOS Region some links to corporate servers but unsuccessfully. BIOS Region si coreboot type, i tray to use phoenix tool to disassemble it but again unsuccessfully. Using official information on https://kodi.wiki/view/Archive:Chromebox, flow all steps in documentation for reset of device i can't have succuss. I found in documentation that firmware can be found i Hromebox OS, but i haven't access to terminal/shell window to start:
      Download and run the ChromeOS device Firmware Utility script using the following command (hit enter afterwards):
      cd; curl -L -O https://mrchromebox.tech/firmware-util.sh && sudo bash firmware-util.sh
      Select option 9, Restore Stock Firmware
      Choose whether to restore from a backup file on USB or not
      If not, select your ChromeBox model so the appropriate firmware can be downloaded
      After restoring the stock firmware, reboot, and proceed to Perform_a_Factory_Reset above to restore/reload ChromeOS
      • peste
        • 12792
        • ROMANIA
        try..
        • ogabuga
          • Dec 2013
          • 12
          Hi Peste, thanks for the quick reply, I tested your BIOS but it doesn't work, when reinstalling the OS it continues with corporate enrollment. I also worked on the BIOS Region and found the address of the block that contains the corporate enrollment command. The address of the block in BIOS Region is 1f8600 - 1f873f, I am also attaching the block itself, I hope this information will be of useful to you. I am also attaching the BIOS I made, it is with clear ME Region and there is no corporate enrollment.
          • BMCappelletti
            Asus Chromebox CN62 - wrong chip put on BIOS reader
            by BMCappelletti
            Long story short:
            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
            - gave the computer to his son a couple years later
            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
            (seems like the story was not that short)
            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
            01-08-2025, 07:27 PM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            Today, 05:12 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • MDSI
            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
            by MDSI
            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
            Details:
            Model : HP OMEN 17-an012nf
            Motherboard Part Number : DAG3BAMBAF0 REV : F
            Serial Number (S/N) : 5CD7280D51
            BIOS chip : Winbond W25Q64VSIQ
            Programmer : EZP2023+
            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
            I already...
            07-28-2025, 07:11 AM
