HP T730 password locked BIOS
  • migelius
    • Aug 2022
    • 5
    Hi all.
    I bought a thin client, HP T730 that came with locked BIOS. Nothing worked to reset it (jumper etc.), I tried everything. Even tried to put a random password three times to get a "final" lock code, but nothing happens. I can access BIOS, but cannot change anything, and that's where the main issue is. The PCIe slot is disabled which makes this unit useless.
    I am not sure what route should I take now. I was going to do some additional research, but cannot get to the actual BIOS chip. This is the first time I see a clip like this. How in the world I can remove the BIOS chip from the slot (see the attachment, it is not soldered.)
    Also, I would appreciate any advice at this point. What possible options do I have?
    Thank you all in advance.
  • peste
    • Dec 2016
    • 12973
    • ROMANIA
    Re: HP T730 password locked BIOS
    Originally posted by migelius
    Hi all.
    push from the left (see the posted picture) in a horizontal plane of the port above the bios chip and then lift the end of the port..
    • migelius
      • Aug 2022
      • 5
      I was able to remove the top cap and now I can access the BIOS chip.
      Is CH341A programmer (like on the screenshot) would allow me to make a dump of it?
      • Aditya11ttt
        Adi
        • Feb 2019
        • 184
        • India
        yes u can make dump with ch341a
        • migelius
          • Aug 2022
          • 5
          Thanks.
          • migelius
            • Aug 2022
            • 5
            I was able to pull the chip from the motherboard and write new (latest available) bios with neo programmer. After rebooting I could get into bios menu and all options were accessible. I used CH341A usb adapter and a clip, but had to do couple fixes to the programmer. If you ever going to use CH341 programmer, please search CH341 3.3v fix.
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • traxformania
              TONGFANG "GM7TG7P" Bios Password Problem?
              by traxformania
              I tried :
              -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
              11-15-2023, 07:32 AM
            • tlindi
              Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
              by tlindi
              Sublect line continuation: ... Jaguar IDS PC aka Panasonic
              Ack
              Ack
              01-30-2025, 04:26 AM
            • Nopslide
              by Nopslide
              04-01-2024, 04:27 PM
            • BlackVisor
              How to Decode BIOS password for RedmiBook Pro15 2022 6800H
              by BlackVisor
              RedmiBook Pro 1542022 6800H
              SKU: TM2113-39463
              Model Number: RMA2204-AB
              CMIIT ID: 2022AP1835
              SN: 39463/22WD01355
              BIOS version: RMARB5B0P1010 20230628
              1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
              2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
              3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
              01-14-2024, 06:35 AM
