Asus z170-pro bios
  • Naji Tarrab
    • Aug 2016
    • 22
    • Turkey
    Asus z170-pro bios
    Hello, please file the bios, thank you.
    ASUS Z170-PRO
  • Naji Tarrab
    • Aug 2016
    • 22
    • Turkey
    Re: Asus z170-pro
    Originally posted by Naji Tarrab
    Hello, please file the bios, thank you..
    ASUS Z170-PRO
    thank you
    • hoaca388
      Badcaps
      • Jan 2022
      • 12314
      Re: Asus z170-pro
      Z170-pro
      • Naji Tarrab
        • Aug 2016
        • 22
        • Turkey
        Re: Asus z170-pro
        Originally posted by hoaca388
        Z170-pro
        Thank you, but the same problem, the motherboard does not work and the processor does not heat up
        • hoaca388
          Badcaps
          • Jan 2022
          • 12314
          Re: Asus z170-pro
          Hardware error.
          • Naji Tarrab
            • Aug 2016
            • 22
            • Turkey
            Re: Asus z170-pro
            Hardware error.
            On the old bios it was working but with an error message after 15 seconds shutdown
            • hoaca388
              Badcaps
              • Jan 2022
              • 12314
              Re: Asus z170-pro
              Is this ? https://www.asus.com/SupportOnly/Z17...Desk_Download/
                • 21836
                Re: Asus z170-pro
                Try a different bios version. Download from the Asus support site https://www.asus.com/SupportOnly/Z170PRO/HelpDesk_BIOS/ ,extract from the zip folder,open the bios with UEFITool and select Action -> Capsule -> Extract body .That will remove the 2kb capsule header leaving the 16,384KB bios as a *.rom file,you can rename it to *.bin
                UEFITool https://github.com/LongSoft/UEFITool/releases
                • Behroz
                  • Apr 2019
                  • Iran
                  Re: Asus z170-pro bios
                  hi i need asus z170 a bios
                  thank
                    • 21836
                    thank
                    Off topic. Start a new thread with your request or use the same method as post #8 to extract the bios from the Z170-A support page https://www.asus.com/us/supportonly/...helpdesk_bios/
                    • to5it0
                      by to5it0
                      Yesterday, 01:35 AM
                    • Sebastian Codrean
                      BIOS file for ASUS F542UN laptop
                      by Sebastian Codrean
                      Hello to all of you! I need help with a BIOS file.
                      The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                      So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                      02-20-2025, 10:25 AM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • caglarec2268
                      Asus X515EA Bios File Please
                      by caglarec2268
                      merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                      Now "please follow the steps below to recover your bios" text remains on the screen
                      I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                      laptop model x515ea-bq945w
                      s/n: R4N0CV02K527148
                      CN:HWFB
                      Board model; ASUS X415EA R7.0
                      bios chip: GD25Q128...
                      11-27-2024, 03:51 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
