hello every one need help with vostro 330 aio bios
  • amr soliman
    • Oct 2015
    • 123
    • egypt
    ihave dell vostro 330 aio with empty bios file
    when reading the bios chip with rt809h it say chip empty write with 0xff
    here is the original empty file and exe file from dell website if any one can help me
    thx
  • amr soliman
    • Oct 2015
    • 123
    • egypt
    Re: hello every one need help with vostro 330 aio bios
    any one have this file please
    DELL VOSTRO 330 - IPPIP-CP REV.A00.BIN
      • 21841
      thx
      Run the exe and leave the message box on screen,go to C:\ProgramData\WINFLASH (you will have to change folder options to show hidden files and folders to see it) ,copy the BIOS.BIN somewhere, then click on quit in the message box. Change your folder options back as they were,so you don`t accidentally delete any system files or folders.
      • amr soliman
        • Oct 2015
        • 123
        • egypt
        SMDFlea
        you are a life saver thanks man
        May God increase your knowledge
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
        • maanee11
          Help to get Lenovo BIOS bin file for Thinkpad T560
          by maanee11
          Hello Everyone,
          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
          05-15-2022, 11:59 AM
