hp 280 pro g5 sff (Milton REV:0A M11)
  • sundarkanini
    • Aug 2017
    • 155
    • india
    need bios
    PCB code - Milton REV:0A M11
    I have attached the old bios file also
  • hoaca388
    Badcaps
    • Jan 2022
    • 12322
    Re: hp 280 pro g5 sff (Milton REV:0A M11)
    Here
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • joshAU
      BIOS file for N550JK (original dump attached)
      by joshAU
      Hi all.
      I'm looking for a BIOS file for an Asus N550JK.
      I have a Asus R552J, which I believe is identical to the Asus N550JK.
      I downloaded the latest BIOS (210) for the R552.
      It is named N550JKAS.210.
      The BIOS file is however only 6mb in size.
      I've read the chip with a CH341A programmer and verified the file.
      That file is actually 8mb in size.
      I'm wanting to remove the BIOS password from this unit.
      It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
      08-09-2022, 08:06 PM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • Forest79
      by Forest79
      07-23-2023, 07:39 AM
