MSI h97m-g43 Working bios
  • zPwN!
    ENOVA NE14I310 XU133t rev 1.3 working BIOS
    by zPwN!
    Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
    Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
    System SKU NE14I310
    BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
    Motherboard XU133T rev 1.3
    Serial Number IPNBI3X240SM2A01095
    Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
    RAM 8.00 GB
    NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...
    01-03-2025, 01:03 AM
    by Vesko356
    08-11-2023, 03:27 AM
  • Sparklingx
    CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
    by Sparklingx
    So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
    So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
    now all...
    08-29-2024, 01:53 PM
  • titomno2
    Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
    by titomno2
    Hi guys,
    On motherboard ACER AN515-52 type LAF951P.
    I fixed issue with not starting computer (it was the PQ201 component not working properly).
    But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
    Basically some HDD spin but are not detected by the bios.
    Already tried following:
    checked the 4 data lines
    #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
    #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
    07-28-2024, 08:30 AM
  • TraJikar Mac
    [HELP] G712LWS BIOS capsule
    by TraJikar Mac
    I need someone that can capsulate one of the bios files below, and i prefer the older bios version so i can flash it using CH341A tool into the bios chip.
    The manufacturer BIOS files are bigger than the BIOSbackup1.bin files by 256KB and I don't know how to fix or recompile it.
    You can see in this link a conversation between me and other people (Starting at page 10) who tried to help me (thanks to their efforts), but i still couldn't fix it and the laptop is considered as dead until now.
    Also, I uploaded a backup file for the bios that I extracted by using CH341A...
    06-11-2025, 01:35 PM
