bios LENOVO A540-24ICB ib360sl1
  • giogipala
    • Jun 2008
    • 10
    This all in one does not turn on.
    just a little flash of the no cc led,
    does anyone have the dump bios?
    Mtoherboard ib360sl1
  • hoaca388
    Badcaps
    • Jan 2022
    • 12403
    Re: bios LENOVO A540-24ICB ib360sl1
    Post your original bios file and serial number here.
    • giogipala
      • Jun 2008
      • 10
      Sn:yj00teps mo: Yjn0s99230dj
      • hoaca388
        Badcaps
        • Jan 2022
        • 12403
        A540-24ICB All-in-One (ideacentre) - Type F0EL
        • giogipala
          • Jun 2008
          • 10
          thanks but I tried several files but it doesn't work.
          now maybe i found a CC.
          But without schematic and bdv is it difficult for anyone to have it?
          • giogipala
            • Jun 2008
            • 10
            on pc172 i have CC
            • playmedia
              Playmedia
              • Jul 2018
              • 20
              • United Kingdom
              Hi, can someone help me with a new bios for the Lenovo a540-24icb ibsl360sl1 rev 1
              serial: YJ010GKK type: F0EL
              • hoaca388
                Badcaps
                • Jan 2022
                • 12403
                • playmedia
                  Playmedia
                  • Jul 2018
                  • 20
                  • United Kingdom
                  Thank you
                  • spmetroil
                    Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                    by spmetroil
                    I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                    The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                    I have a CH341A programmer and I already attempted the following steps:
                    1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                    2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                    3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                    08-19-2025, 09:23 AM
                  • AHmad_Salal
                    Need BIOS Dump/ROM for Lenovo Thinkstation p500
                    by AHmad_Salal
                    Hello all,
                    I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                    11-28-2023, 05:28 AM
                  • HotSaladMan
                    Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                    by HotSaladMan
                    *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                    Model : Lenovo ThinkBook 14S Yoga ITL
                    S/N : MP28JT19
                    MFG Date : 2022/02/09
                    Factory ID PRC4
                    MO : MPNXB26080FX
                    MTM : 20WE001US
                    MODULE FCC ID : PD9AX201NG
                    IC : 1000M-AX201NG
                    BOARD INFO
                    FLV34 LA-KO51P
                    REV : 1B 2020-08-24
                    Bit of Info
                    Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                    chip id, so i would always uncheck the id check, so it would bypass the error
                    i did in fact make...
                    11-07-2024, 07:46 AM
                  • bestrafer
                    Lenovo L460 LAN issue after BIOS dump flash
                    by bestrafer
                    Hello everyone.
                    I have L460 Type 20FV (2 X 8MB bios chips) with no boot issue after BIOS update (black screen with restarts, common issue on this model + BIOS update).
                    BIOS dump(s) from this post https://www.badcaps.net/forum/showpo...7&postcount=27 makes the laptop boot absolutely fine, no delays, etc..
                    But there is an exclamation mark in the device manager for the LAN card right after fresh OS installation - LAN naturally doesn't work. I saw requests like "BIOS: fix LAN" on other sites.
                    Could someone point on a direction...
                    01-31-2023, 01:14 PM
                  • Nicola Bianchi
                    Lenovo x1 nano gen 1 -- bricked -- where to flash the bios/fw
                    by Nicola Bianchi
                    Hello!
                    A few days ago I bricked my Lenovo x1 nano gen 1 while updating the bios/fw from linux.
                    No the machine power up, but it stuck in a recovery state and I can not do much.
                    Lenovo X1 Nano Gen 1
                    Type: 20UN - X021US
                    S/N: R9 - 10W2D9
                    I would like to flash a new BIOS/FW on the chip using a CH341a programmer but ... I actually don't know which "chip" on the motherboard to target 🤦‍♂️
                    So here I am to ask for help.
                    I opened the laptop and I found a chip that may be the target, on it I've:
                    Winbond 25R256...
                    01-11-2025, 09:50 AM
