hp prodesk 400 g7 small form factor pc
  • saveriuccio
    • Dec 2017
    • 16
    • italia
    Hello everyone
    please who owns the bios file
    for this pc hp prodesk 400 g7 small form factor pc
    • 20807
    Re: hp prodesk 400 g7
    Originally posted by saveriuccio
    Hello everyone
    Post your backups and serial number
    • saveriuccio
      • Dec 2017
      • 16
      • italia
      hi
      it is not locked the bios is corrupt
      I need the file.bin to reprogram it
      • saveriuccio
        • Dec 2017
        • 16
        • italia
        seriale CZC145CTJ0
          • 20807
          hi
          Post it,even if it is corrupt
          • saveriuccio
            • Dec 2017
            • 16
            • italia
            thanks
              • 20807
              thanks
              try this one
              • saveriuccio
                • Dec 2017
                • 16
                • italia
                it worked
                Thank you very much
                  • 20807
                  it worked
                  Thank you very much
                  • Arrow16
                    • Apr 2022
                    • 229
                    • Philippines
                    help hp prodesk 400 g7 small form factor pc bios password
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      Originally posted by piernov
                      — You are requesting help
                      If you do not abide by the following rules, your post will be deleted.
                      You MUST NOT:
                      • Post a request in multiple threads
                      • Post a request multiple times
                      • Arrow16
                        • Apr 2022
                        • 229
                        • Philippines
                        hp prodesk 400 g7 microtower bios password
                        no luck on rc unlocker
                        Last edited by SMDFlea; 10-29-2022, 01:52 AM. Reason: bios removed,already posted once.Thread merged. Multiple posts deleted.....
                        • peste
                          • Dec 2016
                          • 12748
                          • ROMANIA
                          Re: hp prodesk 400 g7 microtower bios password
                          the RCUnlocker tool tells you in the window that you have worked on the wrong chip... look for a 16 MB chip on the board and use the tool on it..
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11711
                            hp prodesk 400 g7
                            • Arrow16
                              • Apr 2022
                              • 229
                              • Philippines
                              Originally posted by hoaca388
                              hp prodesk 400 g7
                              thank you for this
                              • Arrow16
                                • Apr 2022
                                • 229
                                • Philippines
                                hp prodesk 400 g7 Small Form Factor PC
                                hp prodesk 400 g7 SFF bios password
                                need to remove bios password no luck rc unlocker only 32mb chip connected no 16mb chip. TIA...
                                serial #: 1CZ15203K6
                                Product #: 440F3PA#A2K
                                (9DH29AV)
                                • volinakis
                                  • Jan 2021
                                  • 2728
                                  • N/A
                                  Re: hp prodesk 400 g7 Small Form Factor PC
                                  (9DH29AV)
                                  try. it will enter in MPM mode, press F10 and you have a tab under "Main" named " set machine unique data" and you'll find all data on stickers of back of the bottom cover. to exit MPM mode use BCU 4.0 under windows or restart laptop how many times counter shows.
                                  • Arrow16
                                    • Apr 2022
                                    • 229
                                    • Philippines
                                    i try this one but tne unit blinkkiing wwhite aand red, no display the unit is good b4, but after flash this bin file the unit blinking
                                    • volinakis
                                      • Jan 2021
                                      • 2728
                                      • N/A
                                      check contacts of bios chipset, it should work. apply a small pressure on wson8 chipset after heating it.
                                      • Arrow16
                                        • Apr 2022
                                        • 229
                                        • Philippines
                                        ill try reflash again thhe unit allready on, but still have bios password
