hp prodesk 400 g7 small form factor pc
    Re: hp prodesk 400 g7 Small Form Factor PC
    Originally posted by charlie0816 View Post
    ill try reflash again thhe unit allready on, but still have bios password
    Here
    Become a Badcaps supporter
    Thanks to all supporters.
      no way, since you can enter in bios setup and can modify fields it means it has no password. load factory defaults and restart, you'll have a surprise ...
        anŷway sir thnk you fôr your help, 😊
          Re: hp prodesk 400 g7 small form factor pc
          Good day! Can anyone unlock mine for same unit, HP Prodesk 400 G7 Small Form Factor PC BIOS Locked.
          Serial #1CZ0390DKQ
            Hi have have a prodesk 400 g7 where it had a password and I flashed with with an bin from the hp website but now no display and even flash back the backup I'm still getting no display. this is currently going to be an issue with my boss
              Here is a copy of it
                Serial #1CZ0390DKQ
                Serial : 1CZ0390DKQ
                  File corrupted
                    Originally posted by hoaca388 View Post
                    File corrupted
                    thanks for the swift update but is there anything I could do to bring back the pc up?
                      File's corrupted
                      File's nomal
                      Reread your chip at least 3 times, compare to see if it's the same. This error is mainly caused by the programmer.
                        im unable to change settings on bios of prodesk 400 g7 sff
                        i already forgot the admin bios password
                        i can log in upto windows is there a way to reset the bios setup password?
                        if so please guide me im new to this
                        what else do i need to unlock the bios or if its possible to reflash bios while on windows?
                          Buy yourself a programmer and use it to read your BIOS chip and upload it here with the serial number.
                          https://www.badcaps.net/forum/troubl...21#post1622421
                            prodesk 400 g7
                            Sl no;4CE214BGJP
                            9CZ71AV
                            Unit powering ON and stuck with hp logo,Not entering to bios also,Please help..
                            Backup file attached
                              Originally posted by binoj View Post
                              prodesk 400 g7
                              Sl no;4CE214BGJP
                              9CZ71AV
                              HP ProDesk 400 G7 Microtower PC (55X90ES)
                                Hi, need clear ME, and password after replace PCH
                                HP ProDesk 400 G7
                                S/N: CZC224BFR5
                                P/N: 9CY18AV
                                Now it turns on, but it takes a very long time to start, and there is a password at the BIOS entrance
                                  hp prodesk 400 g7 microtower pc
                                  Serial 4CE211CV0N
                                  BIOS IC Model gigadevice 25B256dfig
                                  Bios Problem.
                                    SMDFlea commented
                                    Editing a comment
                                    Post your backup in a zip or rar attachment
                                  #37
                                  Is it possible to upgrade the bios of the hp prodesk 400 g7 sff pc so that it will support the i7-11700k processor? I believe according to the intel site, the 400 series chip set in the pc should support this processor. I just need a bios that does. Any help is appreciated.
                                    try changing the ME region with clean (15.0.47.2521 corporate H) this is for i7-11700k.
                                    coz the hp prodesk 400 g7 is only for 10th gen ME 14.1 Corporate H.
                                      Thanks for the advice rex98. Where can I find the download for 15.0.47.2521 corporate H? Thanks.
                                        hello,
                                        kindly unlock bios password for hp prodesk 400 g7.
                                        serial number is scratched. 4CE211B4.....
                                        Product number: 9CY16AV
