hp prodesk 400 g7 small form factor pc
  • anmunoz531
    • Jul 2024
    • 26
    • Colombia
    #41
    Hi everyone, i trying to repair this desktop and make two long beeps and two short beeps, i´ve read about this and maybe the bios is corrupted, so, how can i repair it, wich tool is needed... thank you for your answers.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12423
      #42
      Originally posted by winbond
      hello,
      kindly unlock bios password for hp prodesk 400 g7.
      serial number is scratched. 4CE211B4.....
      Product number: 9CY16AV
      Post EC file . The main bios file has nothing to unlock.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12423
        #43
        You must have a programmer to write / read the bios file (refer to model CH341A, this is the cheapest model, there are also more expensive models on the market, of course better).
        Attach the bios backup file and serial number here.
        • anmunoz531
          • Jul 2024
          • 26
          • Colombia
          #44
          Hi, thanks for answering me, well, i have the programmer based on CH341A, but:
          1. I dont know wich software use to read / write the bios memory, in this case is a 16 pins one
          2. The bios info is corrupted, so i believe that if i read the software could be bad, so i need also the clean software
          3. My serial is 1CZ1060B1R ; machine type HP PRODESK 400 G7 SFF PC
          i´ve done the repair procedure of bios memories for lenovo machines, but hp is my first one.
          All the instructions are very functional for me
          Thanks a lot.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12423
            #45
            Thanks a lot.
            Always back up the original bios even if it is corrupted.
            https://www.badcaps.net/forum/troubl...21#post1622421
            • anmunoz531
              • Jul 2024
              • 26
              • Colombia
              #46
              Hi, thank you for your help, well.. I´ve read the bios memory successfully, so here is the backup file, named with the type of machine and serial number.
              I don´t know if the bios has configured with password.
              Greetings from Colombia, and i´ll be wating for new instructions.
              Thanks a lot
              • hoaca388
                Badcaps
                • Jan 2022
                • 12423
                #47
                Thanks a lot
                HP ProDesk 400 G7 SFF PC (1Y6G8LT)
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12423
                  #48
                  Hi thank you for your help, the board of HP ProDesk 400 G6 was damaged, if you pressed the power on button it dont hold the on status and inmediatly you stop press button, it power off... i changed the mobo and works perfectly, now, i have 2 more, one prodesk 400 G7 and one 400 G6, both with bios damage..
                  How can i do to based on the other bios files, change its sn and reset bios password to upload it to the damaged bios machines?
                  How can i support you for your help?
                  Post original bios anh serial here.
                  • anmunoz531
                    • Jul 2024
                    • 26
                    • Colombia
                    #49
                    Hi thanks for your answer, here are the two files, named with model and serial
                      • 22167
                      This thread is only for the G7 .Post your G6 request in the G6 thread,if there is one,otherwise start a new thread. Serial numbers should be Typed as text,not only included as part of the file name. Read the rules please !
                      • anmunoz531
                        • Jul 2024
                        • 26
                        • Colombia
                        #51
                        Sorry... It won´t happen again
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12423
                          #52
                          Hi, i have a broken bios of HP400 G7 SFF PC.
                          Serial number: 1CZ10609XH
                          Thank you in advance
                          • anmunoz531
                            • Jul 2024
                            • 26
                            • Colombia
                            #53
                            Hi the last HP400 G7 SFF PC.
                            Serial number: 1CZ10609W0 , Machine type:1Y6G8LT
                            Thank you in advance​
                              • 22167
                              Can`t you give feedback on the last one before asking for another. Is it working
                              • anmunoz531
                                • Jul 2024
                                • 26
                                • Colombia
                                #55
                                Thank you for your help, all files had worked fine, really an excellent work.
                                • anmunoz531
                                  • Jul 2024
                                  • 26
                                  • Colombia
                                  #56
                                  Done, really very helpful all your work
                                  • dhan
                                    • Jun 2018
                                    • 134
                                    • hp
                                    #57
                                    Hi, need clear password
                                    HP ProDesk 400 G7
                                    S/N: 1CZ03501YV
                                    P/N: 264M7PA
                                    thank you​
                                    • dhan
                                      • Jun 2018
                                      • 134
                                      • hp
                                      #58
                                      HP ProDesk 400 G7
                                      S/N: 1CZ03501YV
                                      P/N: 264M7PA
                                      thank you​
                                      edit: No need. I figure it out. thanks.
                                      • hanz07
                                        • Oct 2021
                                        • 18
                                        • phillipeness
                                        #59
                                        please builds no display
                                        HP ProDesk 400 G7 Small Form Factor PC TYRION/TOMMEN REV A
                                        s# 1CZ129047S
                                        P# 440F3PA#A2K
                                        THANK YOU IN ADVANCE
                                        • binoj
                                          BBK
                                          • Nov 2017
                                          • 27
                                          • united arab emirates
                                          #60
                                          HP ProDesk 400 G7 Microtower PC (55X90ES)
                                          ITS WORKED 👍
