Asrock motherboard h81 pro btc rev 2.00
  • OKRPKCOMP
    • Dec 2020
    • 429
    • PAKISTAN
    Bios working but first screen comes late
    Anybody help, working bios
    Last edited by OKRPKCOMP; 05-08-2022, 07:29 PM. Reason: Forget to attach bios dump
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    Re: Asrock motherboard h81 pro btc rev 2.00
    Originally posted by pashacomp
    bios working but first screen comes late
    anybody help, working bios
    try
    extracted from support site
    • OKRPKCOMP
      • Dec 2020
      • 429
      • PAKISTAN
      H81 pro btc rev 2.00 first display comes late
      Hi
      Plz help
      i have working working asrock H81 PRO BTC REV 2.00 motherboard , but its first display comes late
      working bios attached here, somebody plz cean it for fast display
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        Re: H81 pro btc rev 2.00 first display comes late
        hi
        plz help
        i have working working asrock h81 pro btc rev 2.00 motherboard , but its first display comes late
        try
        • OKRPKCOMP
          • Dec 2020
          • 429
          • PAKISTAN
          Originally posted by qayyum786
          try
          Thanks for reply
          i tell u after checking
          • OKRPKCOMP
            • Dec 2020
            • 429
            • PAKISTAN
            Originally posted by PASHACOMP
            Hi
            Plz help
            Thank you
            100% working
            • OKRPKCOMP
              • Dec 2020
              • 429
              • PAKISTAN
              try
              Thankyou bro, its also wroking
              same case here
              INTEL DQ35JOE
              WORKING BIOS, BUT FIRST DISPLAY COMES LATE
              PLS DO IT ALSO[ ****************
                • 20709
                same case here
                INTEL DQ35JOE
                Off-topic in this thread !!! https://www.badcaps.net/forum/showthread.php?t=81160
                • glovecaps
                  Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                  by glovecaps
                  I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                  My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                  The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                  11-25-2024, 04:23 PM
                • dragon3x
                  After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                  by dragon3x
                  Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                  power on.
                  Here are some examples :
                  (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                  switching supply area).
                  (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                  than 6.3 V.)
                  1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                  I replaced capacitors with aluminum-polymer.
                  3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                  03-21-2025, 02:46 PM
                • oragano
                  ASUS ex-b250-V7 motherboard bios corrupted - by me
                  by oragano
                  hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                  So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                  i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                  10-17-2024, 02:53 AM
                • AkaBukai
                  Is it okay to flash stock bios onto the motherboard's BIOS?
                  by AkaBukai
                  Hi there,
                  I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                  The little LED on the power button is flashing slowly and nothing happen.
                  This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                  So I decided to flash the BIOS using a cheap programmer.
                  And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                  I also...
                  12-19-2024, 12:15 PM
                • paulwal
                  Updating a BIOS on ASROCK
                  by paulwal
                  Hi. I am not too up on installing BIOS so am looking for a little direction installing a BIOS update.
                  https://www.asrock.com/MB/AMD/AB350%...index.asp#BIOS
                  I have an ASROCK AB350 Pro4 that is running a P3.00 BIOS.
                  CPU is AMD Ryzen5 1500X which I believe is a "Summit Ridge."
                  Before I go ahead and update it to the latest version, I thought I would ask whether my plan is right to try and be sure I don't make a mess of things.
                  It appears that the latest BIOS for this chip is the 5.80; therefore I need to install (one at a time)…
                  10-02-2023, 04:13 PM
