Bios HP 600 G6 bios
  • nmedalacabeza
    • May 2022
    • españa
    Bios HP 600 G6 bios
    Hi All, i'm getting this error message.. "HP Endpoint Security Controller Problem
    There is a problem with the HP Endpoint Security Controller on the unit
    Please contact HP Inc. to have the unit serviced ".. after trying to program HP 600 G6 mini bios chip. Could someone help me remove it (by new bin file), that actually works?? :-)
    Have attached my original bios file
  • peste
    • 13573
    • ROMANIA
    Re: Bios HP 600 G6 bios
    try this .. enter the bios and restore the security settings to the default values and restart the system ...
    • nmedalacabeza
      • May 2022
      • españa
      Hello, thanks for the answer, I did what was indicated and I'm still the same.
      I would need to remove the bios password that has this *bin.
      it would be possible
      Thank you
      • peste
        • 13573
        • ROMANIA
        Thank you
        to delete the password use RCUnlocker.
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
        • maanee11
          Help to get Lenovo BIOS bin file for Thinkpad T560
          by maanee11
          Hello Everyone,
          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
          05-15-2022, 11:59 AM
