Msi h61m/p31/w8 ms 7788 rev 1.0 bios
  • saiga87
    • Oct 2020
    • 5
    • Việt Nam
    I need bios file for mobo:MSI H61M/P31/W8 MS 7788 REV 1.0 (*.BIN).
    And I hope how to extract BIN file from Bios file downloaded MSI official website. I downloaded and unzip with Winrar it have *.360 extension (its version of bios firmware). Can use UEFI Tool??
    Thank a lot!
  • peste
    • 13557
    • ROMANIA
    Re: Msi h61m/p31/w8 ms 7788 rev 1.0 bios
    Thank a lot!
    use the "bin" extension and the HxD program ...
    • saiga87
      • Oct 2020
      • 5
      • Việt Nam
      it mean i simply change its extension replace *.360 by *.bin??
      • peste
        • 13557
        • ROMANIA
        complete only with ".bin", but you have the bios extracted by me ... just write it ... before making a copy of the original bios ..
        • saiga87
          • Oct 2020
          • 5
          • Việt Nam
          I will try it. Thank a lot buddy
          • ashan000
            • Jul 2022
            • 34
            • Sri lanka
            i need ms7788 v4.0 bios bin please
              • 21841
              MSI don`t post bios versions by board revision,only by motherboard part number.
              If the bios above isn`t working you have a hardware problem.
              • to5it0
                by to5it0
                10-24-2025, 01:35 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • m1ch43lzm
                by m1ch43lzm
                Hi everyone
                09-06-2025, 05:47 PM
              • Forest79
                by Forest79
                07-23-2023, 07:39 AM
              • Fr33man
                BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                by Fr33man
                I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                *Novo button power on
                *Disconnected internal battery...
                09-23-2024, 01:16 PM
