Bios reset on Motherboard ADVANTRON EBC-EA01PSM
  • banane
    • Mar 2021
    • 6
    I try to get rid of the power on / bios password on a small industry mainboard I found.
    It has "EBC-EA01PSM Rev.A101-2" printed on.
    The internet tells me it was sold on aliexpress for a while ???
    Removing the bios battery gives me at least the following information on top:
    American Megatrends Version 2.15.1226.
    Any ideas what to flash on it to make the pw dissapear? I already took a dump of the bios.
    Banane
  • banane
    • Mar 2021
    • 6
    Re: Bios reset on Motherboard ADVANTRON EBC-EA01PSM
    Opening the dump with UEFITool I found a NVAR entry called "OEMDEFAULTPWDSetup".
    How can I edit this entry ?
    Fixed: Yes
    Base: 638h
    Header address: FFC00638h
    Data address: FFC00656h
    Offset: 5F0h
    Variable GUID: F2403E02-AE55-40F4-ABD9-E21EC2E8E8FD
    GUID index: 8
    Full size: 1Fh (31)
    Header size: 1Eh (30)
    Body size: 1h (1)
    Attributes: 83h (Runtime, AsciiName, Valid)
    • banane
      • Mar 2021
      • 6
      Tried to clear all the NVRAM with 00h, did not help.
      • banane
        • Mar 2021
        • 6
        I can't believe it, I found the password via AMITSEDecrypt.py, see https://www.badcaps.net/forum/showth...etup+Decryptor.
        I think the Advantech AIMB-224 is the same, by the way.
        @EineWildeStehlampe, vielen, vielen Dank :-)
        • glovecaps
          by glovecaps
          11-25-2024, 04:23 PM
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • sheffieldyorky
          ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
          by sheffieldyorky
          Hey there people
          While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
          This is what I tried, but not in any order.
          Google
          YouTube
          BIOS
          Command Prompt (administrator privileges)
          On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
          10-25-2025, 02:22 AM
        • oragano
          ASUS ex-b250-V7 motherboard bios corrupted - by me
          by oragano
          hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
          So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
          i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
          10-17-2024, 02:53 AM
        • AkaBukai
          Is it okay to flash stock bios onto the motherboard's BIOS?
          by AkaBukai
          Hi there,
          I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
          The little LED on the power button is flashing slowly and nothing happen.
          This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
          So I decided to flash the BIOS using a cheap programmer.
          And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
          I also...
          12-19-2024, 12:15 PM
