Dell Optiplex 5080 micro BIOS lock
  • soti
    • Mar 2014
    • 9
    • greece
    Hey, does anyone have a solution for this?
    bios password and computrace(absolute) are enabled.
    FXWQD93 8FC8
  • mirbytes
    Banned
    • Jan 2022
    • 4
    Re: Dell Optiplex 5080 micro BIOS lock
    FXWQD93 8FC8
    @soti
    I will help you,
    post a new dump, before the new reading disconnect all batteries including the CMOS.
    • soti
      • Mar 2014
      • 9
      • greece
      Originally posted by mirbytes
      @soti
      I will help you,
      can you explain what you mean? I desoldered flash of the board before reading.
      • soti
        • Mar 2014
        • 9
        • greece
        Ok so I replaced the bios region of the file (second half) with an "empty" one which I pulled from a DELL bios update package (used older version, same as mine).
        Booted and password/computrace/express tag are STILL there!
        I cannot find a second flash on the motherboard, I looked many times.
        Do I also also have to clear ME region? I found the express tag in there but could ME also hold bios pass? Doesnt make sense
        • soti
          • Mar 2014
          • 9
          • greece
          Solved!
          Ok I did it...
          I didn't have to clear ME, I just removed a chunk of data from the EC region manually.
          If anyone needs help with this model, reply here.
          • samuelnagy
            • Feb 2017
            • 16
            • Egypt
            Re: Solved!
            Ok I did it...
            hello, i need this bios because it's locked and have a password
            i need clear one please
            • soti
              • Mar 2014
              • 9
              • greece
              Re: Solved!
              can you pull your bios dump and post it?
              • kumarchennupati
                • May 2020
                • 4
                • india
                Please help Bios Password
                • soti
                  • Mar 2014
                  • 9
                  • greece
                  Try and let me know.
                  • kuszkusz
                    • Oct 2023
                    • Hungary
                    Hello!!
                    Help this file
                    Does it work in Dell optiplex 5080SFF PC?
                    Thank you for your help
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11807
                      Originally posted by kuszkusz
                      Hello!!
                      Help this file
                      No ,It's a micro, if you want a new file you have to post your bios file here (even if the bios is broken) with the service tag number.
                      • hieu13pro
                        • Jun 2023
                        • 31
                        • viet nam
                        Hello, can you help me?
                        My Dell Optiplex 5080 reports a bios error, flashing 3 yellow 6 white. This is the original bios I backed up
                        service tag: dj3p053
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11807
                          OptiPlex 5080 Small Form Factor
                          Service Tag: DJ3P053
                          • hieu13pro
                            • Jun 2023
                            • 31
                            • viet nam
                            thank you, very good
                            • matthewSK
                              • Aug 2024
                              • 4
                              • Slovakia
                              I bought two 5080 micro secondhand and tried to update BIOS on one of them. Strange thing to me is that BIOS version was 0.13.24 which I cannot even find on dell website neither I can find asset tags on support page. Not sure if I was scammed and those are just faulty computers but they booted once I got them and one is still working fine. I tried to update to lowest possible BIOS as first step and it failed. Unfortunately after update only black screen, no BIOS, no POST. I didn't make a backup before of course.😶 So I dumped BIOS from working one but I'm getting error about different asset tag and I'm not able to change it in BIOS. Attached are two BIOS files, corrupted one and another working one from second system. Can anybody help me to fix corrupted BIOS? I tried HEX editor but it didn't work for me. Is it possible to create latest BIOS version with already set asset tag? Because I'm worried that if I try to update it again, it will fail. Or at least to have old BIOS working for faulty PC.
                              WORKING PC TAG: 9G9QB23
                              FAULTY PC TAG: BD9QB23
                              Thanks a lot.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11807
                                TAG: BD9QB23
                                • matthewSK
                                  • Aug 2024
                                  • 4
                                  • Slovakia
                                  TAG: BD9QB23
                                  Small Form Factor is a typo because I have micro versions? Or does it matter?
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11807
                                    OptiPlex 5080 Micro
                                    • matthewSK
                                      • Aug 2024
                                      • 4
                                      • Slovakia
                                      Unfortunately none of those two versions works. Still the same error. I tried to save the service tag in the BIOS but after it reboots it's the same again. Like BIOS won't remember service tag and PC's always in the same loop. Thanks a lot for your time and effort.
                                      • jas7o
                                        • Feb 2023
                                        • United Kingdom
                                        Solved!
                                        Ok I did it...
                                        Hi
                                        How you get option for change service tag ?
                                        I try replace in bios part with dell update one, and get maintenence mode but no option for change service tag in my old 5070 this method works for changing service tag
                                        Can you explain what you do "...I just removed a chunk of data from the EC region manually..." to get option change service tag ?
                                        • mrrubik
                                          Dell Optiplex 7010 micro bad BIOS flash?
                                          by mrrubik
                                          Hi folks,
                                          I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                          After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                          Steps I took:
                                          1. Read BIOS with CH341a, verified hash twice
                                          2. Patched
                                          12-23-2024, 04:11 PM
                                          DELL OptiPlex 5080 OptiPlex 5000 i3-10100 Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 5080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 5080 boardview and OptiPlex 5080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL OptiPlex 5080 OptiPlex 5000 i5-10500T Specification for Upgrade or Repair
                                          09-12-2024, 03:36 PM
