Lenovo ThinkCentre M700z Bios Request
  • lrservicios
    • May 2016
    • 137
    • españa
    Hi all !
    I have above model and power led blinks when i plug the AC charguer and doesnt turn on, i suspect bios is corrupted.
    Please clean Me section
    Here i attach ORIGINAL DUMP
  • mayss
    • Nov 2016
    • 30
    • Polska
    Re: Lenovo ThinkCentre M700z Bios Request
    Your cleaned bios file is attached.
    • lrservicios
      • May 2016
      • 137
      • españa
      Thank you it worked Perfectly
      • lrservicios
        • May 2016
        • 137
        • españa
        New Thinkcentre M700z
        Hi all !
        I have ANOTHER Lenovo ThinkCentre M700z Bios Request
        • mayss
          • Nov 2016
          • 30
          • Polska
          Your cleaned bios file orginal2 is attached.
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • TylerHyde21
            Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
            by TylerHyde21
            Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
            I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
            I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
            This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
            06-29-2024, 10:38 AM
          • Kentsfield
            Lenovo Thinkcentre M75n DMI Data extraction from dumped BIOS
            by Kentsfield
            I got a Lenovo Thinkcentre M75n (MT-M 11G5 PF3XG5V3) with a semi-bricked bios.
            Short recap: I want to add an external GPU via the M.2 slot (Oculink). It does work but has some problems with the onboard GPU of the Ryzen 3 3300U. So I used Smokeless_UMAF to disable it. Since then I don't get any video via the external GPU nor the iGPU and Can't access the BIOS, but the PC does boot to the OS.
            I desoldered the flash IC MX25U12872F and dumped the flash.
            I also downloaded the newest BIOS and have it as a .bin file (I loosely compared the contents...
            08-04-2025, 07:46 AM
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
          • personanongrata
            Help Lenovo Workstation P910 BIOS Request
            by personanongrata
            Dear all, I found this forum and this is my last hope. I had a problem with BIOS update though Windows Update - it was stuck for an hour and I decided to restart. Then it bricked. The reason to update was, I had no video on my panorama display. I tried to find a BIOS on my own, but it seems that Lenovo doesn't provide a complete file, only the BIOS section. Is there any chance someone could repair it? I did a backup from the chip, attached. I also tried using another BIOS, slightly different revision. It worked and even I had a display working, but then Windows tried to update once again and it...
            Yesterday, 11:19 AM
