M5A97 EVO bios bin file
  • nissimezra
    • 178
    Attached the old bios
    thx
  • peste
    • 13562
    • ROMANIA
    Re: M5A97 EVO bios bin file
    thx
    bios extracted from the Asus site update.
    • nissimezra
      • 178
      thank you vey much
      Can please send a link how to extract it?
      Thank you again
        • 21841
        thank you vey much
        Thank you again
        Just extract the exe using 7-zip or winrar, the file size is 4,096KB its the full bios https://www.asus.com/supportonly/m5a...HelpDesk_BIOS/
        Some other asus bios have a capsule header that needs removing/deleting . Post #3 https://www.badcaps.net/forum/showthread.php?t=76841
        • nissimezra
          • 178
          Thank you very much!
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • joshAU
            BIOS file for N550JK (original dump attached)
            by joshAU
            Hi all.
            I'm looking for a BIOS file for an Asus N550JK.
            I have a Asus R552J, which I believe is identical to the Asus N550JK.
            I downloaded the latest BIOS (210) for the R552.
            It is named N550JKAS.210.
            The BIOS file is however only 6mb in size.
            I've read the chip with a CH341A programmer and verified the file.
            That file is actually 8mb in size.
            I'm wanting to remove the BIOS password from this unit.
            It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
            08-09-2022, 08:06 PM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
          • Forest79
            by Forest79
            07-23-2023, 07:39 AM
