Re: Need Ecs H61h2-m3 please
Thank you so much!!
ecs_h61h2-m3-v1_bios dumpAttached Filesif you find these attachements useful please consider making a small donation to the site
I only have this:
Re: Please help.. I need the ECS H61H2-M3 bios bin file
Following is what I found:
https://drivers.softpedia.com/get/BI...01272011.shtml
But unzips a .CAP file, not a .BIN - and < 4MB
could you share the file again? the link no longer works, thank you.Leave a comment:
@DLJ - Dump current chip contents and send to me, I will fix you BIOS with stock version
*Edit - Is this V1 or V2 board? Here is both, latest BIOS with ME 8 FW
If your BIOS chip is only 4MB chip, then you can only use the V1.0 BIOS
http://s000.tinyupload.com/index.php...55417651385887Last edited by BIOSG3tta3; 11-13-2020, 06:23 AM.Leave a comment:
Please help.. I need the ECS H61H2-M3 bios bin file, does anyone have? please share..
ThanksTags: None
by testaccgtaHi, everyone!
I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
- Loading...
