Asus P8B75-M LX DUMP BIOS
  • khelane
    • Apr 2015
    • 172
    • xxxx
    Hi
    I wanted the Asus P8B75-M LX BIOS file (backed up by IC itself)
    I gave this file to one of the users, but when I program the IC, after installing the IC, the motherboard turns on and off quickly, and this cycle continues until I turn off the power.
    When I program the second BIOS file, the motherboard turns on but does not display an image (the second BIOS file belongs to the motherboard itself)
    If anyone has backed up the motherboard BIOS directly from the IC BIOS, please upload it to me.
  • peste
    • 13568
    • ROMANIA
    Re: Asus P8B75-M LX DUMP BIOS
    Originally posted by khelane
    Hi
    try..
    • lotas
      • Jan 2016
      • 4785
      • Russia
      Try this dump.
      • khelane
        • Apr 2015
        • 172
        • xxxx
        tnx for all
        it work and motherboard started
        • biosfucker
          • Oct 2021
          • Sri Lanka
          Originally posted by lotas
          Try this dump.
          yes its 100% working thanks brother
          • Allvision
            • Apr 2014
            • 22
            • Brasil
            Try this dump.
            1000% ok
            • Hachune
              • Sep 2022
              • 10
              • IN
              Asus P8B75-M LX Rev 1.02 ME
              I am looking for a ME file for my Asus B75M-LX, I have searched everywhere and this is the only one I have found.
              https://www.badcaps.net/forum/showthread.php?t=97907
              It works but there are multiple things still not working on my motherboard. I can simply download the BIOS file from official website but the ME file isn't available there. So I just want to try another file if anyone has it apart from the link given.
              Thanks.
              • Rinxx
                • Sep 2020
                • 9
                • United States Of Mars
                Nvm
                • Hachune
                  • Sep 2022
                  • 10
                  • IN
                  I believe someone merged my thread without reading my post.
                    • 21850
                    Your post was read,then merged.The bios at post #2 is working, you havn`t mentioned what parts on your board aren`t working, you most likely have some other hardware issue.
                    • enversefa
                      • Oct 2016
                      • 25
                      • istanbul
                      Try this dump.
                      Dump Working Thank you :puf:
                      • WolfyComrad
                        • Jun 2024
                        Try this dump.
                        Thanks a lot! I was able to repair my motherboard.
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
                        • Sebastian Codrean
                          BIOS file for ASUS F542UN laptop
                          by Sebastian Codrean
                          Hello to all of you! I need help with a BIOS file.
                          The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                          So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                          02-20-2025, 10:25 AM
                        • DynaxSC
                          by DynaxSC
                          06-14-2024, 03:49 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • kodox
                          Asus ExpertBook B1400CB Bios Dump Needed
                          by kodox
                          need original bios dump, original bios has flashed by other technician before me.
                          attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                          unit info:
                          Model: Asus ExpertBook B1400CBA-0711A1235U
                          S/N: R6NXNZ006657238
                          CN: 7F6F
                          Mainboard Code: B1500CBA R2.1...
                          08-16-2025, 12:20 PM
